I jest got a new defiant smart lock and would like to add it to hubitat.
Is there a device driver for defiant smart lock. If not then can someone make me one?
Looks like a Home Depot brand that uses WiFi, and it’s presumably a proprietary thing.
It would be up to Home Depot to make it possible for any other systems to directly pair with their locks. Which seems unlikely to me.
Agree quick search and it doesn’t appear that there is a home assistant integration either.
Homeassistant: Hubspace Integration.
.jdeath/Hubspace-Homeassistant: Hubspace Integration for Home Assistant (github.com)
Looks like the GitHub repo for a home assistant integration.
If you also use home assistant then you could probably use Hubitat’s home assistant device bridge to also control the device from Hubitat.
I was wanting to see if anybody could integrate it or record it to work with hubitat?
