Yeah, I have no experience with them at all.
Good to know, thanks!
djwolf - How did you run wires to each of these room locations?
Trunking.
Just FWIW, the HomeSeer sensors may give constant false alarms if you live in an area with high humidity .
I think mine had a bad cable, but HomeSeer said it wasn't malfunctioning - that humidity is just too high where I live (mid-atlantic, which means it supposedly won't work in some of the largest metro areas in the US, but I digress). Ended up returning it.
That is pretty cool. Is there an easy way to make them battery powered?
Did you get both leads on the Aeotec to report separately?
There was something weird about the device when I first installed it. Component driver with child devices and I seem to recall maybe children didn’t update but parent did. It’s about time for me to test it again so will let you know in a few days.
So, lots of good feedback, however it's still blurry to me when identifying a solid product which is powered via hard line, perhaps with battery backup. Anyone else?
Very sorry for the delay I just tested this sensor monitoring my sump pump today. I can confirm that the child component devices on the Water Sensor 6 do update separately.
