I have a rule to feed my Cats every 6 hours starting at 1:30 am, so they get fed at 1:30, 7:30,1:30,7:30. Since cats don't know anything about DST, I wanted to move the trigger back this morning to start at 12:30.
Have you thought of using a periodic schedule instead, and set it to 30 minutes after the hour at 1, 7, 13 and 19? That would provide the same and I think would automatically adjust to the new time.
It is using periodic, just doing at number of hours after start time.
It wouldn't auto adjust I don't think because the hub time itself changes. During DST I want them fed at 1:30/7:30/1:30/7:30, when not DST (now) I want them fed at 12:30/6:30/12:30/6:30. Since I don't think it will auto adjust, that means it's more to change when time timezone changes (update 4 hours instead of 1)
How about setting two rules one with a predicate condition going from the start and end date of Daylight time, and theother for the dates of standard time with the relevant trigger for each?
Might work for not today, but that. Current problem is I can't set it to start at 12:30. When I say that is the start time, it somehow moves it to 1:30. If I set 11:30 it goes to 1:30, if I set it to 1:30 it goes to 1:30. So I literally can't set the time to start at 12:30 am right now
Please be specific. Looks like it ran every two hours, right? Please show the Scheduled Jobs from App Status page (gear icon). But that's from yesterday! Do you have two instances of that app installed?
For the original issue, the rule was running, simply on the old time not the new one. This morning, it is correctly showing starting at 12:30, so it clearly has something to do with DST and how the rule is handling date/time on the specific day DST starts/ends (I recall having this issue last time but I rebooted and tried again the next day and thought I imagined it).
