I cannot create a global Hub variable of type DateTime. The problem is within the Set initial date for varname. I can enter a the dd/mm fields but it will not accept any year. No problem setting this same type within RM
Hub C8-Pro (tried C8 and C7 as well)
Version: 2.5.0.159
I am able to create a new DateTime hub variable without issue.
However, I note your hub is set to “dd/mm”, whereas mine is “mm/dd”. Perhaps that’s the difference.
No thats I typo. The Set initial date for field is actually mm/dd/yyyy
I did find a work around. I enter the yyyy first then the mm/dd and it works. weird…
