Something definitely going on, it's a new issue to me. I just posted over in another thread, seems to be a lot of people experiencing this
The nice thing is if you do not catch it growing then you wake up in the morning to a welcome screen on HE. Quick restore without your coffee and then you go make coffee.
LOL, thats true!
Well, I guess I should not have just ignored the warning.
I did the soft reset. I see a bunch of runtime exceptions in the logs for automations that tried to run overnight before the hub eventually crashed. All variations of the following error:
java.lang.RuntimeException: java.lang.RuntimeException: java.sql.SQLException: A problem occurred while trying to acquire a cached PreparedStatement in a background thread.
I only did the restore like 10 minutes ago and everything seems fine, but I don't really have time to test it before I leave for work.
EDIT: Looking in backup and restore and it looks like my database barely shrunk in size.
What size is it? May want to reboot and see if it shrinks it; if not try downloading a copy and doing the restore from it; and if all that doesn't work try doing a soft reset with a restore from the downloaded copy.
Hey Folks,
Mine is a steady @ 13m now, far cry from 3371m! I suspect I wasn't far from a crash like what @waterboysh had on his HE. So, I want to setup a notification, but the notification app doesn't do attributes. Would I use RM for this? What do you think would be a good value? 100m?
100m is well within the "safe" range I would guess. Think mine averaged around 120-140 under one of the releases, but now stays around 40-50 on my main hub and 10-15 on dev hub.
How do you see the size of your database? I just realized that the screenshot I posted was the size of the backup file, which is everything BUT the database.
Seems I may written a small driver (Hub Information Driver) to get routine access to that and a few other pieces of data, but you can also check the DB manually using a call to
http://yourHubIP/hub/advanced/databaseSize
The backup file basically is the database, though I don't believe the backup file size necessarily corresponds to the size you'd see in the UI (not sure about the endpoint mentioned above that the Hub Information Driver would also read; guessing that might be closer than me looking at my recent backup sizes or making a new one after seeing that warning in the UI, which I haven't seen lately...).
On my devHub, backup is running in the ~0.6 - 0.75m range with the database reporting 13-15m....
Main hub is a constant 3.4m with a database reporting in at 40-50m
So it's a variable compression rate (as expected with LZF compression)
That's what I use is the
You can pull all kinds of data from that including your DB size. It's pretty cool. Thanks @thebearmay . Now I just gotta figure out the rule for a notification.
Here is mine. Worked in testing but has not reported anything in anger yet as my DB has stayed OK.
Ohhhhhh, that's a nice rule. I have never used the Private Boolean before, and honestly I don't know how. I must do some reading and save that image. Thanks @bobbles
I installed your driver. After the soft reset my DB size is 33. What could possibly have caused it to go from 33 to 2819? Is there a way to see what causes the growth?
The one explanation that I’ve heard that makes some since is that there is a flaw in the database (fix in 2.2.9.x) that causes the database not to reuse space. Issue is triggered when simultaneous writes collide in some fatal pattern.
It's back up to 490m again after only a few days... Is there anything I can do besides doing a soft reset and restoring a backup every few days?
It's up to 610m now. Guess I really should soft reset again.
