C8 2.3.8.128
anyone that knows the local lan link to a dashboard can modify or delete without any authentication. this leaves the hubitat UI exposed to anyone on the network.
I understand that only trusted users would know the link but trusted users are not always intelligent users and can unknowingly modify or delete things.
I would like to see the ability to modify or delete tiles removed from the local lan link functionality. only authenticated users with the correct permissions should be able to modify or delete things.
If your goal is to prevent users from editing a dashboard (intentionally or unintentionally), then that is precisely what the feature @bertabcd1234 referenced is intended to do.
You might also want to toggle off the switch that says โallow logo click to go back to dashboard menu.โ This will prevent the user from accessing another dashboard that you didnโt intend for them to have access to.
The documentation for dashboards is here, if you need to review the available features.
