Dashboard Tiles with Non-Standard Stats
I have a device that that provides a lot of custom stats, like forecastLow, forecastHigh, moonPhase, temperature, uvIndex, and many more.
I'm trying to output some of this data into a dashboard and I've already selected the device in the dashboard configuration menu.
However, when I try to add a tile, most of the templates I'm selecting don't output any of the fields. The only one that's working is the temperature template and it just shows the temperature.
Is there a way to create/modify templates to work with the additional fields the device outputs?
How about the ā€œattributeā€ tile?
The attribute tile will allow you display any attribute the device exposes. As far as custom templates there are a few options, but Iā€™m a little partial to this one:
Thank you very much, that worked!
