Greetings,
I got stuck trying to:
Have a Dashboard tile which does set the level of a Dimmer to a given percent.
(Hubitat C-7 v.2.3.4.114 |Device driver: [1.6.3] - 2022-11-22 (@jtp10181))
So I go to Dashboard > Add Tile > {Selecting my ZEN30} > then the Button Template. The button lets me choose the number of the button and which command to send. I don't see any other option that could be viable.
Then I define a rule,
Trigger:
Office Loft button 4 pushed
Action:
Dim: Office Loft: 10 --> fade: 2
At this step I am aware that I can choose both a vertical and a horizontal dimmer template, but that just places a control slider on the tile. However, I want a tile that, when clicked, sets a definite dimmer level with a definite ramp rate.
I also would assume that I'd rather send the command to the rule machine instead of the dimmer, but there is no such option.
At the end, clicking the tile does nothing.
Looking at dashboard Debug, I see:
"11/28/2022 02:57:22 pm - Sending Command push to id 197
11/28/2022 02:57:23 pm - Command Sent"
The dimmers event log:
Date: 2022-11-28 15:08:58.862
descriptionText: Command called: push
isStateChange: false
physical: false
digital: false
source: DEVICE
type: command
deviceId: 197
The dimmers log shows:
dev:197 2022-11-28 14:57:23.695errorgroovy.lang.MissingMethodException: No signature of method: java.lang.String.call() is applicable for argument types: (java.lang.String, java.lang.String) values: [4, pushed]
Possible solutions: wait(), any(), trim(), size(), dump(), split() on line 538 (method push)
What am I looking at here? Alzheimers light?
TIA,
// Luis
