The default dashboard tile color for a switch is white text with a yellow background. I have trouble reading the white text with the yellow background.
Can I change the tile color to something like white text on dark gray background, to make it easy to read?
If you go into the options in the dashboard (when you have the dashboard open, not the Apps page) and look at the templates, you can adjust colors for different states on the switch template. Note, this will update the colours used by any tile using this template, which may be what you want, but if you want to only change selected tiles, or use different settings on different tiles, you will need to use some custom CSS
