While controlling my home's mini-split system with my Dew Point app, the dashboard virtual thermostat devices sometimes show odd results, such as this case where the mode is Off, but the device appears to be cooling. (The physical mini-splits are off) I've also had it where Mode=cool, with the runningMode= idle. My Dew Point app changes the device mode, but does not adjust the runningMode. In this case it changed from cool to off.
BTW DewPoint AC control rocks!
tagging @bravenel @mike.maxwell
Should you need more info about my system
Using indoor dew-point and node-red to control temperature/relative humidity - #51 by arnb
