Is it possible to have dashboard icons instead of the background image?
Can you also change the text size in the tiles?
Not sure I understand exactly what your asking apart from the obvious. Click the settings cog and adjust Font size.
Also check out :
Docs
Text size per tile. Not globally for the dashboard.
Can you use icons in place of text for dashboard links.
You could set up the dashboard links using ordinary "link" tiles, which gives you the option to specify your own text or images.
