Look for Virtual Keypad by "mbarone" - [RELEASE] Virtual Keypad . There is also "Virtual Basic Keypad" but actually harder to set up.
Here's how I set it up. Hope that helps:
that's the dashboard settings, not what you are looking for.
Find the keypad device in your 'devices' tab/menu item, the 'lockCodes' should be in the 'Current States' section of the keypad device.
You can use the 'set code' function from the keypad device page to set codes you need, or you can separately manage your lock codes using the addon, 'lock code manager'
that was a page I have not seen.
However it still does not work, I guess you mean the child instance. When I press disarm, it just disarms, it is not asking for a code. I have seen that boxes should be marked or unmarked, if it should ask for pincode
And if I cared to read: "Set lock codes in the keypad device or using an app like Lock Code Manager".
What can I do in the blue marked area, tile number?
I have also tried code manager, no joy, maybe I should delete it all and start on a fresh!
