Dashboard Display, Chromebook
Hey Folks,
Just though I would pass along a good experience I am having that may help others in the "I want a larger Dashboard" group. I doubt this is anything new but could be helpful. Chromebooks are very common around my parts, and used ones are going for relatively good prices. I picked up a used ASUS Chromebook Flip 14" for $150 Canadian to try and use it for a dashboad display. It looks like the picture below.
I wasn't sure that Fully Kiosk would run on the ChromeOS due to the disclaimers on the fully website, but to my surprise it's working well. Super simple to setup, load Fully Kiosk on the Chromebook, load the driver in HE and away I went.
  • Easy setup, Fully Kiosk Installs from Play Store
  • Fully Remote Admin works, can make changes to Fully from your PC
  • Battery reporting works, (I have installed with a Zigbee Outlet to charge when low, off when charged) (one quirk in the number of decimal places it reports sometimes, looking into this)
  • Motion Sensing works, I use this to turn off the screensaver and provide a motion sensor for my Living Room
  • Speak works, the TTS engine works very well, can use it for your announcements
  • Siren works, upload your Wav siren sound to HE File Manager
  • Beep works, Same as above, just need your own beep file
  • Screen on / off doesn't work, but I use the ScreenSaver on / off and a black screen for this.
  • ScreenSaver works, can put in your own picture for this or just use a black screen
You can also install Chrome Flex on any old laptop.
I played around with Android x86 on an AIO 21" touchscreen PC I had. It worked, but just wasn't happy with it. Few glitches, either with the sound, the screen functions, etc. After a dozen or so variations of versions of Android x86 I shelfed it and went with a straight up Chromebook. I really like the "flip" option to display it without the keyboard. I must look at the Chrome Flex, never saw that one before.
Chrome flex is much better then android x86. It's made directly by google specifically to turn any x86 pc into a chrome book and extend it's usefulness.
I used CloudReady back in the day and it worked well to save some XP era machines to prolong their life a bit. If Chrome Flex is similar, it should work very well and be super user friendly.
