Or Nest buying Revolv and shutting it down ...
Edit: @SmartHomePrimer read my mind ....
I misread your mind, so had to correct my spelling of Revolv
Nest will eventually have an API again via the Google Assistant. It's taking them way to long, and it's been a cluster#### but it will happen eventually I think.
Google Assistant Service and Google Actions today are only one-way....your devices to Google Assistant for control of your devices by the Assistant. You can't access other Google connected devices through the Google Assistant Service or Google Actions. For example, if you sync your Hue bridge directly to the Google Assistant, you can't access those Hue lights through the Google Assistant in any way other than through voice control. You could not control them on Hubitat this way. So, if they do start offering a 2-way API for devices through the Assistant, that would be a HUGE change.
Who wants to write a Weather.gov API integration for us US folks?
That API won’t be going anywhere...
Edit: I really want to, not enough time these days, though
Hey, with everything going on right now, I don't think anything is 100% certain. But then again, if that happens, I don't think we'll be too worried about the weather either. ![]()
I took a quick look at the API and it looks to be a little TOO detailed. You can't do a direct call based on location info (lat/long or city name). You have to query the API with your location to get the grid reference in their system and the office name that handles your area. Both are necessary to query for your location's info. I also haven't figured out a way to get anything but forecast info. Nothing on current conditions yet. So, this is way above my head, unfortunately. On the plus side, the API does provide a direct link to a weather icon. So, no translating necessary there. However, the icons are all square and pretty bad. But what do you want for government work.
Really big plus side...no API key necessary. You can just start querying to your hearts content.
I use a nifty Android app, NWS Now (https://www.nwsnow.net/), that uses the weather.gov data API. Maybe someone could reverse engineer this app? It has location by GPS, ZIP, or weather station (airport) ID.
NOAA can be a bit confusing. I think you pretty much have to do a zip-lookup for LAT/LON, then, get a station ID for current conditions. Once you have that, you can get all the forecast info needed.
They used to have a static-URL XML generator that was pretty clean, but I don’t think that’s around anymore, and it’s all JSON now.
I’m glad I’m not the only one who thinks their API is confusing haha
Here is an example of current conditions here in Bismarck:
https://api.weather.gov/stations/kbis/observations/current
Figured I'd give weather.gov a quick look this morning. I got it to connect and get the json. My problem is always getting the data out of it! lol
I can connect, download the json (even log the json data) but when I try to pull out the fields I want. I get null's. I've tried all kinds of combinations and each time I get errors like, 'No such field' or 'No such property'. But with the way I have below there are no errors but no data either, just 'null'.
My log showing the json file, 'cwa' is the field that I'm trying to get in my examples:
My Code:
httpGet(requestParams) { response ->
if(logEnable) log.info "In getPointsData - response: ${response.status}"
if(response.status == 200) {
//log.info "${response.data}"
def office = response.data.properties.cwa
log.info "Office: ${office}"
sendEvent(name: "office", value: office)
My log:
Any ideas!?
BTW, I do use this json-parser to get the json formatting.
I think you need to parse the response in JSON before trying to pull the data out. Something like:
obs = parseJson(response.data)
def office = obs.properties.cwa
That should parse the JSON response and allow you to pull out the daata. Although I can't see the top of the JSON so I don't know if you need a 2nd "data" in the def office line.
Thanks, getting an error with that code... it doen't get past the 'obs = parseJson(response.data)'
groovy.lang.MissingMethodException: No signature of method: user_driver_BPTWorld_Weather_Gov_Driver_872.parseJson() is applicable for argument types: (java.io.ByteArrayInputStream) values: [java.io.ByteArrayInputStream@abd76b]
Another json screenshot using the json parser:
sorry...do you have
import groovy.transform.Field
at the top? You probably need to have that to use the parseJson command.
What's the URL you are requesting? That way I can spit-ball myself rather than forcing you to do it.
BAM! That did it... no parseJson needed. I'm off to the races, lol
Thanks again
YAY! Glad I could help.
Wow, this gives a ton of data! Should have something out later today.
example of forecast data:
Yeah, I was looking at it yesterday. It's almost too much data though. Have you looked at the local current observations?
"@context": [
"https://raw.githubusercontent.com/geojson/geojson-ld/master/contexts/geojson-base.jsonld",
"wx": "https://api.weather.gov/ontology#",
"s": "https://schema.org/",
"geo": "http://www.opengis.net/ont/geosparql#",
"unit": "http://codes.wmo.int/common/unit/",
"@vocab": "https://api.weather.gov/ontology#",
"geometry": {
"@id": "s:GeoCoordinates",
"@type": "geo:wktLiteral"
"city": "s:addressLocality",
"state": "s:addressRegion",
"distance": {
"@id": "s:Distance",
"@type": "s:QuantitativeValue"
"bearing": {
"value": {
"@id": "s:value"
"unitCode": {
"@id": "s:unitCode",
"@type": "@id"
"forecastOffice": {
"@type": "@id"
"forecastGridData": {
"@type": "@id"
"publicZone": {
"@type": "@id"
"county": {
"@type": "@id"
"id": "https://api.weather.gov/stations/KBIS/observations/2020-04-03T14:52:00+00:00",
"type": "Feature",
"geometry": {
"type": "Point",
"coordinates": [
-100.75,
46.770000000000003
"properties": {
"@id": "https://api.weather.gov/stations/KBIS/observations/2020-04-03T14:52:00+00:00",
"@type": "wx:ObservationStation",
"elevation": {
"value": 506,
"unitCode": "unit:m"
"station": "https://api.weather.gov/stations/KBIS",
"timestamp": "2020-04-03T14:52:00+00:00",
"rawMessage": "KBIS 031452Z 30006KT 10SM CLR M08/M16 A3030 RMK AO2 SLP294 T10831161 51007",
"textDescription": "Clear",
"icon": "https://api.weather.gov/icons/land/day/skc?size=medium",
"presentWeather": [],
"temperature": {
"value": -8.2999999999999545,
"unitCode": "unit:degC",
"qualityControl": "qc:V"
"dewpoint": {
"value": -16.099999999999966,
"windDirection": {
"value": 300,
"unitCode": "unit:degree_(angle)",
"windSpeed": {
"value": 3.1000000000000001,
"unitCode": "unit:m_s-1",
"windGust": {
"value": null,
"qualityControl": "qc:Z"
"barometricPressure": {
"value": 102610,
"unitCode": "unit:Pa",
"seaLevelPressure": {
"value": 102940,
"visibility": {
"value": 16090,
"unitCode": "unit:m",
"qualityControl": "qc:C"
"maxTemperatureLast24Hours": {
"value": null,
"qualityControl": null
"minTemperatureLast24Hours": {
"value": null,
"precipitationLastHour": {
"value": null,
"precipitationLast3Hours": {
"value": null,
"precipitationLast6Hours": {
"value": null,
"relativeHumidity": {
"value": 53.408724232471876,
"unitCode": "unit:percent",
"windChill": {
"value": -13.583246923922673,
"heatIndex": {
"value": null,
"cloudLayers": [
"base": {
"value": null,
"amount": "CLR"
Every "attribute" has a value key, a unit key and a QC key. I mean, I'm sure this is important to a meteorologist but I just wanna know what the temp is!
I was able to parse out international WorldWeather info earlier today, too.
Turns out, none of this was as difficult as I thought it would be. Didn't have to use any import functions, either—Hubitat's HTTPGet was able to parse everything natively.
Looking forward to seeing the whole thing. I only got to see a few minutes in the middle, wife had me doing things today.
First alpha of the Weather.gov driver is now available on this thread.
I think you have it misfiled in apps. Couldn't find it at first.
