Danalock Status Updates
Hi,
I have a Danalock v3 which works fine but fails to update the status after a while when locked manually. I am using the generic zigbee lock driver. If I go through the process of re-pairing it will work for a few days but then will stop reporting again. Works fine when using HE to perform operations, it's only when manually operating the lock. If I manually operate the lock and then go to the device within the HE app and click the refresh button the status updates instantly.
Has anyone else had this problem and if so is there a fix for it?
Seen this on a couple different locks caused by locking or unlocking slowly. Not sure why that matters though.
Hi
have you solved the problem?
Your danalock was zigbee or zwave?
