Daikin One Integration
The multi one / Master-child the master will create the children it needs, but the code needs to be loaded on the hub
Tnx for the input. There is progress !
I installed the multi one driver and it did work creating a virtual thermostat of the type master.
It can now read data from the system that I see in the output of 'Current States' for the master device.
But I do not see any child device created as it is the case for the next device in the screenshot (the I/O module). SHould I see a child device ? Also I do not see any command tiles in the device screen beside Initialize / configure.. Is that the design intent or they should appear on the child device ?
2024-04-20 11_03_44-Devices
Thanks for your inputs , much appreciated !
