I have two installations with security systems installed. One is with a large ELK system (45 devices) and the other is with a large DSC system(36 devices). The hubs seems fine but I have never tried to look at the load. Should I be monitoring it?
I think a second hub might a good idea to consider.
The hubitat staff can chime in here with better info but I seem to recall them stating in an earlier thread that it really did not matter unless you were experiencing any problems (lagging, delays, missing actions etc). I just have another hub on hand (purchased during one of the HE sales) as a belt and suspenders kind of guy (also I am impatient so if my primary fails, I donât have to wait around for a replacement). At $100 on sale, its a very cheap insurance policy given how much investment is being put in the system as a whole. I know some in the community have as many as 5 hubs, and kudos to them for maintaining such organized systems. However my approach has always been using the most simple method (as long as it gets the job done properly) as possible to minimize the complexity when trying to diagnose or fix a problem. OTOH, by running multiple hubs at the same time, it can be argued that if one hub goes south, it does not cripple your entire system. I have only been using HE for two years now, but in my experience (using a UPS with it), it has been incredibly reliable, hence my use of only one active hub at a time as that is sufficient to meet the needs of in my use case.
What about rough-ins for displays? Thinking about my own setup, my main 'user front-end' (if you will) is Google. I have Minis and hubs all over the house and predominantly use voice commands for everything. The problem is that not everyone is familiar with using voice commands and the device structure is different for everyone. What this turns into is visitors having no idea how to control devices (think like maid service/dog sitter/etc.). Having some type of front end display in each room would go a long way. Given that the sizes of displays vary so much, I think a setback box with an outlet would do the trick.
I actually include an iPad with any installation that I do. I create an email address for the location and make sure all of the apps are together on the main page.
My hub is fine managing a couple hundred zwave and zigbee devices plus integrations with several Hue hubs, a lutron hub, and a Bond bridge. So no worries there. The envisalink application is the issue. It's community supported and is relatively resource-intensive. I ran for a long time with Envisalink running on my one and only hub but recently decided to split it off onto its own hub. Plus... in the grand scheme of your project I seriously doubt if a $100 hub is going to break your budget
Envisalink can also be offloaded to an rPi box but easier to just toss another HE at it.
Slightly off topic but I just wanted to give props to @brad5 for his excellent documentation on how to offload Envisalink to a secondary hub for those of you who have it on your primary hub and wish to lighten the load on your primary hub to increase performance and to raise the headroom. He did a fantastic job of providing step-by-step instructions here:Help offloading Envisalink processing to another hub.
Thanks again @brad5 !
Definitely put ethernet in the soffits for cameras. At my last house, I ran about 4 times more wire than I thought I needed. It made things really easy when installing new equipment.
Whole house WIRED audio system. Do the proper wiring to the keypad locations and wire for speakers in the ceiling and walls. I have most main rooms covered in this house, and it's great. I do have a Sonos, but it just connects to an input on the whole house system.
What a fun project and thread! Here are my thoughts:
definitely push for speakers. The quality wonât evolve much and the experience of whole house audio is magical. Recommend Sonos Amps driving each zone uniquely
setup Android power boxes for fire tablets to be mounted for home control in key rooms. Install either Sharptools, SmartTiles, or my HousePanel on those tablets. The GUI for these 3 panels are superior to the built in one
not sure your customer will be happy with Hubitat for day to day mobile interactions. Consider giving them an Apple HomeKit integration setup. They are likely to have iPhones and will want an easy way to control things from their smart phones. I use this for my woofie and she loves the CX of HomeKit. The magic of Homebridge that happens behind the scenes is not visible to her
I wouldnât stress too much about wiring. The future is wireless and 5G and beyond. If there is a home theater room you could focus there and provide a high bandwidth link to the server closet.
give some thought to security cameras. Where are they are how are they connected?
offer them a support service. Donât expect they will manage the setup in DIY mode.
Be sure to have a neutral and ground and power in EVERY box.
Also, use at least Cat 6a or 8 Ethernet cable. Consider ways to make the Ethernet cable accessible down the road so it can be easily replaced if needed (without having to tear drywall open).
Use the deepest boxes possible for the switches.
Look at the Inovelli Dimmers. They're super sweet.
If using Lutron RadioRA2, install recessed, ceiling mounted RadioRA2 motion sensors. I would use as much RadioRA2 as the budget allows for a very solid, reliable lighting solution.
