I am setting up a custom rule for a water sensor at my sump pump. What is the "For how long?" setting? I want to monitor 24 hours a day, do I set the value to 1440 Minutes?
For how long should the sensor be in the desired state.
For eg., if you do not wish to be notified if the sensor is in the wet state for 5 or fewer minutes, then you’d set the value to 6.
