The Danfoss models dont report Temp, only the Popp versions do. So you do need temp sensor of some sort to use as a reference, to then set the setpoint of the TRV accordingly.
Hello there, do you know if the drivers for the LC 13 will work with the POPP valves ? I do not need the Temp report as I have other better temp sensors. But I have some POPP valves and I want to be sure before moving them from smartthings.
They should do, although I cant say for sure as I dont have one
Ok, will try and report it when I have time to test this. Thx, and I guess I will have some other questions to ask around here when I get my hub next week !
List should be updated with Yeelight Ceeling4 and Color 6, that is supported in FW: 2.1.8 now.
Great!
RogerThat
That's not a community supported device but a built-in device.
I updated the supported devices wiki, now it just needs to be approved by Hubitat for it to post. Thanks!
Hi.
Added:
GLEDOPTO 12W Dual white and color Zegbee bulb (GL-B-008ZS)(Generic RGBW Bulb Driver)
GLEDOPTO RGB+CCT LED Strip Light(mini usb controller with the Generic driver) AliXpress link to product
Kind regards
RogerThat
Oslo, Norway
Yesterday I added Wink Siren and Chime and Honeywell Z-Wave Thermostat (TH8320ZW) to the list above. I hope I did it right, do I need to add more info? Anything else I can add to be useful?
Added Innr SP 224 Smart Plug, using generic Zigbee or custom Iris handler.
Also Kwikset 888 5-button deadbolt Generic Z-Wave lock. Documentation makes it sound like you can also set it up as Zigbee.
Added GoControl Z-Wave Door/Window Sensor (Linear WADWAZ-1) as Generic Z-Wave Contract Sensor
GoControl Z-Wave PIR Motion Detector (Linear WAPIRZ-1) as Generic Z-Wave Motion/Temperature Sensor
I know they are Linear underneath, which is shown in the main compatibility list, but I thought it might be worth mentioning them by the name I bought them as which was GoControl.
Added Ecowitt GW1000. A low cost weather sensor internet gateway which can be used directly via LAN only with HE.
Added the Abode driver now that it's GA/Stable. Added links to the Ecobee and IFTTT mentions because they looked lonely
@mike.maxwell I recently added a few Sylvania smart+ flex rgbw lightstrips. They paired as generic zigbee bulbs, so I changed the driver to rgbw bulb and they’re working fine.
On the compatible list so maybe the footprint changed? Details during pairing pasted below. Thanks.
Was a driver ever produced for the ubino RGBW controller?
Not yet, no.
@philippe.charette, yuou should add yoru stelpro stuff to this list.
They've been working great for me so far!
Added
Also, it works as a repeater in case anyone is interested.
I added my Trane Z-Wave Thermostats (TZEMT400BB32MAA) to my HE config. They're regular Z-Wave, not Z-Wave Plus, but they registered just fine in-location.
I ran these for a few yrs prior to the Nests they now replace, and they're solid (require C-Wire)
In HE, they work fine with the Generic Z-Wave Thermostat driver, so their details need to be attached for automatic driver selection.
They're this Z-Wave device in Chris's catalog:
- https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/245
he also includes links to the Doc for the device:
I'd like to put in a request for a generic zigbee temperature/humidity sensor.
Konke, Aqara, Tuya, AduraSmart and others make such a device, and I believe that others are coming.
I am currently using for this purpose a community developed Konke driver, but I'd like to use a built in driver.
