Custom Dashboard [Hubidash] Release
even my RP3 works great I have also tested it with RP4 8GB ram. Blazing fast.
Did the 3 only have 1GB ram? That's all I can find on their site...guessing if I went with the RP4 4gb that should cover me for other projects too if I want to repurpose it or give docker a shot :slight_smile:
I will probably toss it into a VM tonight and give it a spin!
I've been watching to see how it goes, only holdup has been not having a pi to run it on but I've been debating getting one for a while anyway. Are you thinking of pulling the plug or just wondering how much interest is out there?
@good.looking.blues you probably want npm installed first here:
sudo npm install -g node-gyp
echo -e "\e[1;45m Installing NPM \e[0m"
sudo apt install npm -y
echo -e "\e[1;45m Installing pm2 \e[0m"
sudo npm install pm2 -g
Not pulling the plug. Just interested what people think of it. It's kinda inspiring to see how a hobby project becomes useful to smbdy else.
I actually should remove npm at all. It's a leftover from the dev process. At that point it's installed anyway. I will tweak it later down the line, thanks for noticing :slight_smile:
Ok cool, I just ordered the Pi and assuming time works out should have this set up next week at some point :slight_smile: At least based on screenshots etc, I'm very interested to see it myself.
When did it get installed? I didn't see it elsewhere in the script .... unless nvm installs it now (it never used to).
(Just getting my head round what's required for a Dockerfile)
Probably node installs it. In any case up to the point it reaches this line - npm is already installed.
I am - but just playing / learning at the moment.
Saw someone with the same error earlier Screen Shot 2021-03-16 at 8.48.08 PM|690x439 but I ran into the same issue using the latest build (1.2.1) ...any ideas on how to get around this?
Also, thanks for putting this together - Excited to get it working
My RPi will be delivered tomorrow and then I will be loading it with Hubidash. I can't wait to try it out and see what it can do. Thank you very much for making this available and I look forward to see what comes next. I would like to see Hubitat Safety Monitor tiles become available.
Most probably instructions where poorly followed at the stage of modifying two key files - .env and monogDB-setup.js.
Tried it again following instructions modifying both .env and mongoDB-setup.js.
Two errors i noticed during the install
  1. This command 'sudo cp -f mongod.conf ../../etc/mongod.conf' generated the following response
    "cp: cannot create regular file '../../etc/mongod.conf': No such file or directory"
I tweaked the command to 'sudo cp -f mongod.conf ../../../etc/mongod.conf' and i believe it worked
  1. During the Hubidash package install I got the following error:
node-pre-gyp ERR! install response status 404 Not Found on https://github.com/kelektiv/node.bcrypt.js/releases/download/v5.0.1/bcrypt_lib-v5.0.1-napi-v3-linux-arm64-glibc.tar.gz
I ran the following command
"sudo apt-get install -y build-essential python"
and then re-ran
(cd ./server/ ; npm install)
and it seemed to clear
Anyway not sure if these are related but I figured it might be worth mentioning.
My set up is an RPi3 Model B with no WiFi
Weird, since I have tested the script on fresh RPis 3 and 4 and none of them had the issues you mention. But I will add that line to the script. Will not hurt.
And regarding the mongod - it might mean that you have tried to change the structure of folders to something other than in Installation Tutorial.
I have this dockerised in a container with just node.js (I already had mongo running, also dockerised).
It's really nice looking and very fast!
I appreciate docker isn't the intended platform, so are there any debug / verbose logging files that I can view so I can troubleshoot any issues from that side?
For example I assume it should real-time update device status but it doesn't so far, could be some ports need mapping or something I missed in creating the container. Does Hubidash use the Hubitat eventsocket or Maker API post for status updates?
I accidentally deleted the part where I have explained how to tweak the Hubitat to work with Hubidash. I'll bring it back soon. But generally - you need to point your Maker API to send post events to Hubidash server (don't forget the port)
the section is now back online at the bottom of the page:
http://www.hubidash.com/installation#hubitat
That's great, all seems to be working now.
Currently pointing it at my development Hubitat, if I point it at one of my other Hubitats in the future do I need to clear the current hubidash database first?
From a docker perspective, other than the .env file, is everything in the hubidash folder expendable? So to update to a new version, I can just rebuild my docker image with the latest hubidash .zip file?
