Custom Apps and Drivers
Hi All. I've installed WebCoRE and love it - very powerful, and worked straightaway. However, I've had no luck installing some other custom apps/drivers, namely the SamsungTV, Sensibo (airco) and Hive home thermostat. Am I doing something horribly wrong, or are these custom apps tricky to get working? Any pointers for how I can find out what's going wrong? (These devices worked in Home Assistant, so I know I have the right config/permissions on them)
You would be best to ask these questions in the explicit forum pages for the custom apps.
Since I am the author of the Samsung TV at: Samsung Hubitat TV Integration (2016 and later)
I recommend you read the instructions "Samsung TV Remote.pdf" At this moment, GitHub is having trouble displaying PDF, but you can download and read.. There are some steps in your TV that must be done prior to the installation.
Echo to use the appropriate topic and also log files with any errors are most helpful.
Just came across this. I setup the Sensibo stuff without any issue.
Did you get it working?
