CT Bulbs not turning on reliably
I have a bunch of Mercator Ikon CT ceiling lights that can be a bit unreliable when combining the built in Generic Zigbee Advanced CT Bulb driver and Room Lighting. Occasionally 2-3 of the 10 or so bulb I have wont activate with RL, but will turn on instantly if I use the On button or Set color Temperature button in the device page.
In this example 'Kayla's Room Light' As activated by RL, and the devices page says its on, but the actual bulb just flickered and stayed off. Then I went to the device page and turned it on. Then I tried turning it off and on with RL and it responds fine. But if I leave it alone for a while it will stop responding to RL activating it again. Using Force doesn't change the behavior.
I can't tell if it's a bug in the bulb hardware, the Generic Zigbee Advanced CT Bulb driver or Room Lighting. I have some Ikea bulbs that use the same driver faultlessly, but then again some of the Mercator bulbs are perfect too. And others fail every second day.
Any ideas? Anything else I can provide to help the RL or HE team troubleshoot it?
This is my RL setup for this room:
Here are the logs:
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:26.145 PM[info](http://192.168.22.31/logs#)DeviceName is null
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:26.142 PM[info](http://192.168.22.31/logs#)sendEvent dcpower=12v
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:26.017 PM[info](http://192.168.22.31/logs#)sendEvent Device FW is current
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:25.916 PM[info](http://192.168.22.31/logs#)DeviceName is null
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:25.910 PM[info](http://192.168.22.31/logs#)sendEvent dcpower=12v
[dev:245](http://192.168.22.31/logs#)2023-08-27 09:20:24.144 PM[info](http://192.168.22.31/logs#)Kayla's Room Light was turned on
[dev:245](http://192.168.22.31/logs#)2023-08-27 09:20:24.142 PM[debug](http://192.168.22.31/logs#)descMap:[raw:catchall: 0104 0300 01 01 0040 00 5B4A 00 00 0000 0B 01 0A00, profileId:0104, clusterId:0300, clusterInt:768, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5B4A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[0A, 00]]
[dev:252](http://192.168.22.31/logs#)2023-08-27 09:20:23.920 PM[info](http://192.168.22.31/logs#)Kayla's Bedside Light was turned on
[app:120](http://192.168.22.31/logs#)2023-08-27 09:20:23.870 PM[info](http://192.168.22.31/logs#)setLevel: Kayla's Bedside Light, level: 100
[app:120](http://192.168.22.31/logs#)2023-08-27 09:20:23.823 PM[info](http://192.168.22.31/logs#)setLevel: Kayla!, level: 60
[dev:245](http://192.168.22.31/logs#)2023-08-27 09:20:23.798 PM[debug](http://192.168.22.31/logs#)descMap:[raw:catchall: 0104 0008 01 01 0040 00 5B4A 00 00 0000 0B 01 0400, profileId:0104, clusterId:0008, clusterInt:8, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5B4A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[04, 00]]
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:23.742 PM[info](http://192.168.22.31/logs#)Calling /white/3?turn=on&brightness=60
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:23.739 PM[info](http://192.168.22.31/logs#)Executing setLevel
[app:120](http://192.168.22.31/logs#)2023-08-27 09:20:23.705 PM[info](http://192.168.22.31/logs#)setColorTemperature: Kayla's Room Light, temp: 6535, level: 100
[dev:245](http://192.168.22.31/logs#)2023-08-27 09:20:23.689 PM[debug](http://192.168.22.31/logs#)setColorTemperature(6535, 100, null)
[app:120](http://192.168.22.31/logs#)2023-08-27 09:20:23.656 PM[info](http://192.168.22.31/logs#)Activating for All Modes
[app:120](http://192.168.22.31/logs#)2023-08-27 09:20:23.635 PM[info](http://192.168.22.31/logs#)Activation Event: 'Kayla's Remote Switch' pushed 1
[dev:251](http://192.168.22.31/logs#)2023-08-27 09:20:23.596 PM[info](http://192.168.22.31/logs#)Kayla's Remote Switch button 1 was pushed [physical]
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:22.531 PM[info](http://192.168.22.31/logs#)DeviceName is null
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:22.527 PM[info](http://192.168.22.31/logs#)sendEvent dcpower=12v
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:22.436 PM[info](http://192.168.22.31/logs#)sendEvent Device FW is current
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:22.347 PM[info](http://192.168.22.31/logs#)DeviceName is null
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:22.343 PM[info](http://192.168.22.31/logs#)sendEvent dcpower=12v
[dev:252](http://192.168.22.31/logs#)2023-08-27 09:20:20.386 PM[info](http://192.168.22.31/logs#)Kayla's Bedside Light was turned off
[app:120](http://192.168.22.31/logs#)2023-08-27 09:20:20.326 PM[info](http://192.168.22.31/logs#)off: Kayla's Bedside Light
[dev:245](http://192.168.22.31/logs#)2023-08-27 09:20:20.300 PM[info](http://192.168.22.31/logs#)Kayla's Room Light was turned off
[dev:245](http://192.168.22.31/logs#)2023-08-27 09:20:20.296 PM[debug](http://192.168.22.31/logs#)descMap:[raw:catchall: 0104 0008 01 01 0040 00 5B4A 00 00 0000 0B 01 0400, profileId:0104, clusterId:0008, clusterInt:8, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5B4A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[04, 00]]
[app:120](http://192.168.22.31/logs#)2023-08-27 09:20:20.271 PM[info](http://192.168.22.31/logs#)off: Kayla!
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:20.183 PM[info](http://192.168.22.31/logs#)Calling /white/3?turn=off
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:20.180 PM[info](http://192.168.22.31/logs#)Executing switch.on
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:20:20.178 PM[info](http://192.168.22.31/logs#)Executing switch.off
[app:120](http://192.168.22.31/logs#)2023-08-27 09:20:20.172 PM[info](http://192.168.22.31/logs#)off: Kayla's Room Light
[dev:245](http://192.168.22.31/logs#)2023-08-27 09:20:20.155 PM[debug](http://192.168.22.31/logs#)off()
[app:120](http://192.168.22.31/logs#)2023-08-27 09:20:20.124 PM[info](http://192.168.22.31/logs#)Turn Off Event: 'Kayla's Remote Switch' pushed 1
[dev:251](http://192.168.22.31/logs#)2023-08-27 09:20:20.079 PM[info](http://192.168.22.31/logs#)Kayla's Remote Switch button 1 was pushed [physical]
[dev:245](http://192.168.22.31/logs#)2023-08-27 09:19:25.391 PM[debug](http://192.168.22.31/logs#)descMap:[raw:catchall: 0104 0008 01 01 0040 00 5B4A 00 00 0000 0B 01 0400, profileId:0104, clusterId:0008, clusterInt:8, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5B4A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[04, 00]]
[dev:245](http://192.168.22.31/logs#)2023-08-27 09:19:25.113 PM[debug](http://192.168.22.31/logs#)on()
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:18:54.209 PM[info](http://192.168.22.31/logs#)DeviceName is null
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:18:54.203 PM[info](http://192.168.22.31/logs#)sendEvent dcpower=12v
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:18:54.113 PM[info](http://192.168.22.31/logs#)sendEvent Device FW is current
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:18:54.017 PM[info](http://192.168.22.31/logs#)DeviceName is null
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:18:54.011 PM[info](http://192.168.22.31/logs#)sendEvent dcpower=12v
[dev:245](http://192.168.22.31/logs#)2023-08-27 09:18:52.217 PM[info](http://192.168.22.31/logs#)Kayla's Room Light was turned on
[dev:245](http://192.168.22.31/logs#)2023-08-27 09:18:52.215 PM[debug](http://192.168.22.31/logs#)descMap:[raw:catchall: 0104 0300 01 01 0040 00 5B4A 00 00 0000 0B 01 0A00, profileId:0104, clusterId:0300, clusterInt:768, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5B4A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[0A, 00]]
[dev:252](http://192.168.22.31/logs#)2023-08-27 09:18:52.030 PM[info](http://192.168.22.31/logs#)Kayla's Bedside Light was turned on
[app:120](http://192.168.22.31/logs#)2023-08-27 09:18:51.974 PM[info](http://192.168.22.31/logs#)setLevel: Kayla's Bedside Light, level: 100
[app:120](http://192.168.22.31/logs#)2023-08-27 09:18:51.930 PM[info](http://192.168.22.31/logs#)setLevel: Kayla!, level: 60
[dev:245](http://192.168.22.31/logs#)2023-08-27 09:18:51.876 PM[debug](http://192.168.22.31/logs#)descMap:[raw:catchall: 0104 0008 01 01 0040 00 5B4A 00 00 0000 0B 01 0400, profileId:0104, clusterId:0008, clusterInt:8, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5B4A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[04, 00]]
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:18:51.810 PM[info](http://192.168.22.31/logs#)Calling /white/3?turn=on&brightness=60
[dev:130](http://192.168.22.31/logs#)2023-08-27 09:18:51.808 PM[info](http://192.168.22.31/logs#)Executing setLevel
[app:120](http://192.168.22.31/logs#)2023-08-27 09:18:51.777 PM[info](http://192.168.22.31/logs#)setColorTemperature: Kayla's Room Light, temp: 6535, level: 100
[dev:245](http://192.168.22.31/logs#)2023-08-27 09:18:51.761 PM[debug](http://192.168.22.31/logs#)setColorTemperature(6535, 100, null)
[app:120](http://192.168.22.31/logs#)2023-08-27 09:18:51.683 PM[info](http://192.168.22.31/logs#)Activating for All Modes
[app:120](http://192.168.22.31/logs#)2023-08-27 09:18:51.665 PM[info](http://192.168.22.31/logs#)Activation Event: 'Kayla's Remote Switch' pushed 1
[dev:251](http://192.168.22.31/logs#)2023-08-27 09:18:51.622 PM[info](http://192.168.22.31/logs#)Kayla's Remote Switch button 1 was pushed [physical]
What does your Zigbee mesh look like? If some are failing every couple of days, you might need to reinforce the mesh with some repeaters.
As for Room Lighting, try changing it from a scene to a group and enabling Zigbee Group Messaging to see if that helps with activation.
Sounds like a Zigbee mesh issue. Stating that after turning them on and off from the device page they work fine, makes me think that this caused them to change routes because of a weak signal and then they worked.
I don't think so, because the on/off button always works, so the signal is getting through. It's something to do with how Room Lighting is activating the light, and maybe something in the lights firmware not liking that - because other brands I have are perfect.
Have you tried using the generic zigbee ct bulb driver, or Sengled driver. If you change drivers, make sure you hit “configure” on the device page.
The "generic zigbee bulb" driver is reliable, but doesn't allow CT, timed fades, etc that the "Advanced CT" Driver does.
