Afternoon all! Really keen to integrate my Risco alarm system, to at least be able to arm and disarm through HE. Risco were meant to be releasing an API last year, but still nothing. I have found a few projects written for mqtt bridge (with node.js), homeassistant and homebridge. How easy would it be for me to convert this into driver code to be used by HE. Not a lot of coding skills but a quick learner, just wondering if this is something I could take on? Cheers...
home-assistant:dev
โ OnFreund:risco_integration
opened 07:39AM - 19 Jun 20 UTC
You are amazing! Thanks for contributing to our project!
Please, DO Nโฆ OT DELETE ANY TEXT from this template! (unless instructed).
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
A new integration for Risco alarm systems, through the [Risco Cloud](https://riscocloud.com/ELAS/WebUI) platform.
This is the first step, with a config flow and an alarm control panel for every partition.
Future PRs will add:
* Group arming support, and user-configurable mapping between groups and the various arm states.
* Optionally require pin code to arm/disarm
* ~~Fetching data through `DataUpdateCoordinator`, in preparation for:~~
* Binary sensors for the zones
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [X] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request: https://github.com/home-assistant/home-assistant.io/pull/14286
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [X] The code change is tested and works locally.
- [X] Local tests pass. **Your PR cannot be merged unless tests pass**
- [X] There is no commented out code in this PR.
- [X] I have followed the [development checklist][dev-checklist]
- [X] The code has been formatted using Black (`black --fast homeassistant tests`)
- [X] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [X] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [X] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [X] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [X] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [ ] No score or internal
- [ ] ๐ฅ Silver
- [ ] ๐ฅ Gold
- [ ] ๐ Platinum
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
system
Closed
September 24, 2022, 10:55am
2
