Ok
I have set up Conditions for the Triggers
Then set up a Conditional Action IF Then..
Set the condition
if x= y then do this
Then setup next Conditional Else If then
Set
If x=z then
Set variable = false
and STUCK......
Nowhere to go
What do I press to complete this and move to the next action?
It is consistent - wiped and deleted this rule three times get stuck at the same point each time.
Looks like a buglet ?
Ha it is an order of action bug
else if x=z then
set variable - dead end stuck
alternative
else if x=z then
do something else
set variable
All Ok
Yup a bug
Nah
Is just getting worse time for an HE reboot
This is probably a browser issue. I just created a rule identical to yours, but for the names of the devices and variable, and had no problem at all.
What browser are you using? Did you try a page refresh?
I think I have worked it out - will document when I finish some more tests
habitat
6
@bravenel All User issue.
But I can see how I ended there -
It was while setting a Else If condition but DID NOT exit the Conditions and went ahead with setting Actions WHILE in Conditions.
IF you miss an exit back a stage you end up in a dead end.
My Bad all on me - but I can see while learning the Is missed that.
Thanks for jumping in - much appreciated
It's supposed to suppress inputs beyond the stage it is in, so I will look into what you're saying.
