Hello,
Trying to created a rule to turn on and off the frezzer using - (negitive value) for some reason it does not seem to work if i add in -
It a SONOFF SNZB-02
Any suggestions?
Hello,
It a SONOFF SNZB-02
Any suggestions?
Negative value where? In the trigger? In a condition? Can you post a screen shot of your rule?
Edit: a quick test and this worked for me so a little more info would be helpful.
You posted in Rule Machine but it looks like you're using Basic Rule. Let me try that.
This worked for me
Your logic says risen above -3.5 then turn off. Isn't that logic backward for a refrigerator?
I wanted to stop it going to -20 so i did risen above. Its a fridge thats now a freezer lol. I change then name in the hub now to freezer.
Going from 0 to -20 would be falling so once it falls below -3.5 then stop (turn off) the freezer would be the correct logic.
