Coway (iocare) driver
Anyone looked at integrating with Coway's IoCare API? Mostly for air filters (specifically the AirMega 300S/400S)
Homebridge example: https://github.com/aschzero/homebridge-airmega
HomeAssistant Example: https://github.com/sarahhenkens/home-assistant-iocare
I have two of the 400s and would like to assist in integrating into Hubitat. Thanks, Joe
has anyone added this to Hubitat ? If so, how did it go. I have Coway 250S
Someone will have to write a driver for Hubitat. Should be possible since it looks like there’s an API and integrations for HA and Homebridge.
I don't have the time to write a driver but I'm still interested in alpha/beta testing and debugging.
I would love to see a driver for Coway filters as well. I would write one if I knew how. I have many Coway filters that I automate through Google Home, but Google just broke them and now the filters just power off when you try to control them. :frowning:
Btw I tried to write a native driver for Hubitat but sadly the access tokens required are not valid for any app but existing approved apps by coway with a client token. I reverse engineered some drivers for homeassistant but the tokens and domains dont work. The last idea is to man-in-the-middle attack the airmegas to spy on their authentication process and replicate, but that's a bit more than I want to do since coway rotates their tokens and domains often and it would require constant maintenance. Why so secure for such a simple device (almost no other smart device is equally actvely secured like this including camera and door locks, which makes this very odd).
Since Matter V1.2 (nearly 3 years ago) - Air purifiers and Air filters have had supported clusters, and numerous vendors make such things - Since Conway is already over Wifi, it doesn't seem like a large ask to have them add Matter support in a future FW release. - Really depends on their future direction, if they want to support an open or closed API.
See:
And specific products/vendors for the HEPA and Air Quality clusters are below:
