Could this switch work with Hubitat?Any experience
I cant find the exact device (i lost the publication) but is exactly like this one of the picture BUT with the US type of plug
Captura de pantalla (191)
Could work with Hubitat? could work with the driver¨ [Zemismart ZigBee Wall Switch Multi-Gang] From Muxa?¨ or ¨ [Moes ZigBee Wall Switch 1/2/3-Gang]¨¨
If the generic zigbee driver does not work, it shows it has an Alexa integration, so it could be controlled by that through HE.
Interesting :speak_no_evil: :speak_no_evil: :speak_no_evil:
@kkossev is our resident Tuya Zigbee guru and would know for sure.
No, there is no way to know for sure whether a Tuya-based device will work on Hubitat out of the box or will require a custom driver or changing one of the existing drivers….
But the chances to make it work are good, at least for on/off functionality.
@TomG so... @kkossev is the guru? i know you( well...Here on the comunity) but i was not aware you was the guru on tuya devices :wink: altough i was aware you was the guru on the Mmwave theme,sensors reviews and drivers...
Maybe in November or december bought one of this switches with plugs,with luck would work an come here to notify if it works,or does not
By the way,Thanks specially for the drivers for the Mmwave sensors,thanks to you they works here on the hubitat
