I could not pair a Kwickset Convert 914C Zigbee 3.0 lock with platform 2.3.8.117 or 2.3.8.118. Last week I had paired another lock just like this one without issue, so I rolled back to 2.3.7.146 which was the platform version I was on when the previous lock paired with out any issues. I was able to pair this new lock w/out issue on 2.3.7.146
I wasn't sure exactly where this info should, so I dropped it into feedback.
I have major issues pairing any Zigbee device both on my c-7 and c8pro the c-7 worked fine until I updated to 2.3.8.118. Devices just donβt pair or quit responding.
I can pair to Alex hub or Smartthings hub without and issue but no luck on and Hubitat
I re-paired the locks and they were still acting weird (only one would work closest to the hub, etc.) So then I ended up changing the channel and power settings for zigbee to see if that cleared up the strange behavior, and it appears to have done so. I'll try updating the hub firmware to see if things still play nice.
I've got a number of APs (five). So I need to keep them on different channels to help with roaming, and not interfering with each other, so I ended up changing to channel 16 as that was the furthest off from the AP in the same room as the hub. I also set the power level to 16. So far so good on the Zigbee and ZWave locks I have. Just need to update the firmware and see if it is still stable.
