Corrupted rule. Can't delete it without "opening" it. Can't open it cuz corrupted
I love Hubitat. I own 3. I have 100+ devices and I write some very complicated rules coordinating activity on multiple properties.
In all that use, I've only found one problem I can't work around....
Some time ago, I edited a rule and the UI threw an error. It was a while ago so I don't remember what the edit action was or what version I was on. I'm sure you've fixed whatever bug I encountered in the meantime.
My issue is that the rule is still partially working (it modifies a hub variable), but I can't edit/stop/delete it. Attempting to "open" it, I get:
Unexpected Error
An unexpected error has occurred trying to load the app. Check Logs for more information.
Error: String index out of range: 10
Info:
  1. The rule does not show up in the "broken rules" test.
  2. The logs for the rule shows only one line:
    app:11772023-08-08 17:47:00.242errorjava.lang.StringIndexOutOfBoundsException: String index out of range: 10 on line 10464 (method mainPage)
  3. Rev C-7 running 2.3.5.152 (latest version at this writing)
How can I delete this rule I can't open?
Thanks in advance,
M.
Use the gear icon next to the app in your Apps list to get to the app status page, then delete it from there.
Wow. So easy.
I never even once hovered over those. Being on the left side and being light-on-dark-on-light, I never recognized that icon as a gear -- I thought it was just like a flowery paragraph bullet or design element. LOL.
Thanks for the super quick and accurate answer!
