Multiple Hue Bridges are supported, but with 5 you'd be pushing the limits...
The issue is how hue bridges only publish all bulb states and hubitat has to poll for changes from that entire list of bulbs.
If the bulbs are phillips and not 3rd party, you might want to do a standalone hubitat hub for the bulbs (or 2 or 3) and use something like hub connect to bring them all into a master control hub.
Yes, but not as bad. The polling is the biggest issue, no polling no issue. But if you don't use the hue app, or other integrations, might as well just put the bulbs on a Hubitat to gain the repeaters.
Can't hurt to try the hue integration with 5 hue bridges.
Zll bulbs fall back to zha and are repeaters. Some bulbs are bad repeaters. Putting Phillips hue bulbs on Hubitat will repeat for non zll zigbee devices. Only some really cheap bulbs don't follow zigvee spec and support zha along with zll.
Thanks so much. All of my bulbs are Hue. I do have another 12 bulbs that are connected via Osram. Hue does not have the form factor I needed for my kitchen ceiling.
Based on the comments above, I am not sure if I need an add'l HE. Will I need it to split the load? Network Coverage? Redundancy? I plan on leaving the 5 HUBS in as I have many situations where I want to manually launch a scene or an automation out of the HUE app, or other 3rd party apps.
Based on my testing, it looks like IFTTT can only "talk" to the bridge that I happen to be connected to via the meethue remote access/cloud service. Will HE help me solve this limitation?
Based on @patrick comments above I would go with a 2 HE setup. One HE has 3 HUE bridges connected and the other HE hub has 2 HUE bridges connected. Reason, as @patrick said, is the way HE needs to poll the HUE bridges and the resources necessary to do so. You can interconnect the two HE hubs by using something like HubConnect and you would be able to control all lights from a single hub.
So, now we're saying that it's good to have ZLL bulbs on Hubitat and they should not go on their own Zigbee network? That is completely opposite to every other piece of advice about ZLL bulbs ever given on this forum by any member of the Hubitat staff or any of the community members.
Uhm.... @mike.maxwell, is this the new recommendation? Hue bulbs are fine to pair directly to Hubitat even when you have ZHA devices on the same mesh?
Bad repeaters are bad repeaters, no matter the zigbee profile.
I have all my bulbs, and nothing but bulbs on a dedicated HE hub, this works well for me.
yes, I have Hue (RGB & RGBW strips, Bloom, Living colors and Lux), Osram (RGBW bulbs and CT panels) , Ikea candelabra bulbs and AduroSmart CT bulbs, 23 total so far scattered around 3 floors with one repeater, and the dedicated hub for them in a non optimal location...
As Mike said above, bad repeaters are bad repeaters. Phillips Hue bulbs are fine repeaters. Other 3rd party ZLL bulbs are bad repeaters.
As a blanket statement, it's a good idea to separate your ZLL bulbs, if you can or want to. But if you have high quality bulbs that make good repeaters, its perfectly fine to have them in a ZHA mesh.
Choice is good, strong mesh is even better.
The other main reason we typically recommend bulbs on their own, is people tend to put bulbs in things that can be switched off, unplugged, etc. A zigbee repeater that drops off routinely can cause excessive battery drain in devices (they go into panic mode, high power and try to find another neighbor to join) and obvious packet loss until the mesh heals.
I have learned a bunch following this discussion, but dome recent comments have me confused. I was tracking until the impact of light bulbs being turned off was brought up. It seems like using Hue hubs protects the network from that problem?
Do I want to attach my 185 bulbs direct to HE, or do I want to attach my 5 Hubs.
Speed/performance considerations?
If I go without Hue bridges, am I still able to utilize all of the IOS apps?
Also, are there any videos on how to instalj HubConnect. I am missing something. I never see or can find the Oauth prompts, I think n step 2 or 3. I have been able to install the built in apps, but this is my first import.
Last of all, is there a way to have both HEs in the same dashboard?
'Mirror' all devices from the 2nd hub to the 1st and run Dashboard from the 1st.. one set of dashboards with devices from all your HubConnected Hubs (SmartThings, too.)
Nothing will protect you from that, the problem is ZigBee lamps are designed to be left powered ON all the time so that they create a strong mesh for themselves and the other devices on that network. Turning the power off to them will cause no end of issue.
I prefer them on my HE hub but that's because I only have lamps and a few buttons on my ZigBee network so they run fine. There is no limit to the amount of lamps you can have on HE providing the hub is in a central location to them (purely for speed reasons).
Yes but this is when it becomes tricky, if you change something in the app it is not instantly updated in HE where as if they are connected to HE directly when you make a change in HE obviously it knows about it. So if your running automations from HE is can cause the sync issues if you control the lamps from the Philips app.
This answer is a bit confusing... the OP asked he he goes WITHOUT Hue bridges, can he still use the Hue iOS App. The answer is actually no.
I believe the OP should keep the Hue bulbs on his Hue bridges. This allows the use of the Hue App on the phone, Hue direct integration with Alexa/Google, bulb firmware updates, power loss/restore features, etc...
The Hubitat to Hue Bridge Integration is via the LAN, so no real disadvantage to keeping the bulbs on the Hue bridges, except the sync issues mentioned above.
