When rule machine converted this basic rule, it changed the 'off' to 'on' and failed to convert the requirement of 'Only when not disabled by Vacation on'.
When Time of Day is 9:00 AM, turn off Guest Bedroom Fan-F, Pool Bedroom Fan-F, Master Bedroom fan-F
Basic Rule
Pause Rule
When Time of Day is 9:00 AM ...
Turn off Guest Bedroom Fan-F, Pool Bedroom Fan-F, Master Bedroom fan-F
Rule and pending actions can run ...
When the ...
Time of Day Is
A certain time ā¦
at
09:00 AM
Erase Time
Do this action:
Turn off
Delete
Add Another Action
Add Wait Until ā¦
Had basically the same thing happen to me today. Let me preface that Iām a new user and this was my first time trying this. But the final portion of the basic rule when converted to rule manger I had changed from off to on. So I had to change it back to off to make it the same as it was before.
I can confirm the same issue. Basic rule of contact opens, light turns on, contact close, light turns off. I just brought it into rule machine and everything was good except the last step. Rule machine made it turn light on instead of turn light off.
I donāt suppose this is a big deal, but it is still happening. When you convert a basic rule, it will convert off to on and on to off. just backwards.
