I need convert a simple rule from Rule Machine to Simple Automation Rule :
Tiger is a switch, when turn on then turn off after 30 minutes.
Thanks .
The funny thing is that simple automation does not exist in simple automation. I have always been told, go use RM. Maybe this can be revisited? @bravenel
Some people created apps to do this as well. I have a personal one that I created, @bertabcd1234 has one that uses one switch to control another, but can be used for only one switch.
This simple rule ( RM ), lock the door when the door closed :
I don't need use a big knife to cut a lemon . Simple Automation Rules !!!
Just use
Garage Entry Door "closed"
Action: Lock: Garage Entry Door Lock
No need for "changed" and the IF-THEN.
Hi @bravenel , can I convert these rule from Rule Machine to Simple Automation Rules ?
