I was wondering if there was a possibility of your converting your ST (Model: SC-ZWAVE5-ECO) driver to HE. I'd gladly support your patronage if you would be able to do so.
Thank you and Happy Holidays.
The Built-in driver doesn't work?
Converting the ST DTH to Hubitat is as simple as replacing the 7 instances of "physicalgraph" with "hubitat" That will allow the Driver to compile. Does it work??
* Ecolink Siren v1.0
* (Model: SC-ZWAVE5-ECO)
* Author:
* Kevin LaFramboise (krlaframboise)
* The device is fully functional if selected as switch:
* - Switch On: Siren On
* - Switch Off: Turns Everything Off
* - Set Level 10%: Chime/Beep
* - Set Level 20%: Entry/Continuous Tone
* - Set Level 30%: Exit/Repeating Beep
* Changelog:
* 1.0 (07/17/2018)
* - Initial Release
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Ecolink Siren", namespace: "krlaframboise", author: "Kevin LaFramboise") {
capability "Actuator"
capability "Alarm"
capability "Switch"
capability "Tone"
capability "Refresh"
capability "Health Check"
capability "Switch Level"
attribute "lastCheckIn", "string"
command "continuousTone"
command "repeatingBeep"
fingerprint mfr:"014A", prod:"0005", model:"000A", deviceJoinName:"Ecolink Siren"
simulator { }
tiles(scale:2) {
multiAttributeTile(name:"switch", type: "generic", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label:'${name}', action:"switch.off", icon:"st.alarm.alarm.alarm", backgroundColor:"#e86d13"
attributeState "off", label:'${name}', action:"switch.on", icon:"st.alarm.alarm.alarm", backgroundColor:"#ffffff"
standardTile("siren", "device.alarm", width: 2, height: 2) {
state "default",
label:'Siren',
action:"alarm.both"
standardTile("off", "device.switch", width: 2, height: 2) {
state "default",
label:'Off',
action:"alarm.off"
standardTile("refresh", "device.refresh", width: 2, height: 2) {
state "default",
label:'Refresh',
action:"refresh.refresh"
standardTile("beep", "generic", width: 2, height: 2) {
state "default",
label:'Beep',
action:"tone.beep"
standardTile("continuousTone", "generic", width: 2, height: 2) {
state "default",
label:'Continuous Tone',
action:"continuousTone"
standardTile("repeatingBeep", "generic", width: 2, height: 2) {
state "default",
label:'Repeating Beep',
action:"repeatingBeep"
main(["switch"])
details(["switch", "off", "siren", "refresh", "beep", "continuousTone", "repeatingBeep"])
preferences {
input "debugOutput", "bool",
title: "Enable Debug Logging?",
defaultValue: true,
required: false
def updated() {
if (!isDuplicateCommand(state.lastUpdated, 2000)) {
logTrace "updated()..."
state.lastUpdated = new Date().time
initializeCheckin()
private initializeCheckin() {
def checkInterval = (6 * 60 * 60) + (5 * 60)
sendEvent(name: "checkInterval", value: checkInterval, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
startHealthPollSchedule()
private startHealthPollSchedule() {
unschedule(healthPoll)
runEvery3Hours(healthPoll)
def healthPoll() {
logTrace "healthPoll()"
sendHubCommand([new hubitat.device.HubAction(versionGetCmd())])
def ping() {
logTrace "ping()"
// Don't allow it to ping the device more than once per minute.
if (!isDuplicateCommand(state.lastCheckInTime, 60000)) {
logDebug "Attempting to ping device."
// Restart the polling schedule in case that's the reason why it's gone too long without checking in.
return [versionGetCmd()]
def siren() {
logDebug "siren()..."
return getOnCmds(sirenEP)
def strobe() {
logDebug "strobe()..."
def both() {
logDebug "both()..."
def setLevel(level, duration=null) {
if (level == 20) {
return continuousTone()
else if (level == 30) {
return repeatingBeep()
else {
return beep()
def on() {
logDebug "on()..."
def off() {
logDebug "off()..."
return getOffCmds()
def beep() {
logDebug "beep()..."
return getOnCmds(beepEP)
def continuousTone() {
logDebug "continuousTone()..."
return getOnCmds(continuousToneEP)
def repeatingBeep() {
logDebug "repeatingBeep()..."
return getOnCmds(repeatingBeepEP)
private getOnCmds(endPoint) {
return delayBetween([
basicSetCmd(0xFF, endPoint),
basicGetCmd(endPoint)
], 50)
private getOffCmds() {
def cmds = []
endPoints.each {
cmds << basicSetCmd(0x00, it)
cmds << basicGetCmd(it)
return delayBetween(cmds, 50)
def refresh() {
logDebug "refresh()..."
def cmds = []
endPoints.each {
private versionGetCmd() {
return secureCmd(zwave.versionV1.versionGet())
private basicSetCmd(val, endPoint) {
return multiChannelCmdEncapCmd(zwave.basicV1.basicSet(value: val), endPoint)
private basicGetCmd(endPoint) {
return multiChannelCmdEncapCmd(zwave.basicV1.basicGet(), endPoint)
private multiChannelCmdEncapCmd(cmd, endPoint) {
return secureCmd(zwave.multiChannelV3.multiChannelCmdEncap(destinationEndPoint:endPoint).encapsulate(cmd))
private secureCmd(cmd) {
if (zwaveInfo?.zw?.contains("s") || ("0x98" in device.rawDescription?.split(" "))) {
return zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
else {
return cmd.format()
private getCommandClassVersions() {
0x20: 1, // Basic
0x59: 1, // AssociationGrpInfo
0x5A: 1, // DeviceResetLocally
0x5E: 2, // ZwaveplusInfo
0x60: 3, // Multi Channel (4)
0x72: 2, // ManufacturerSpecific
0x73: 1, // Powerlevel
0x7A: 2, // Firmware Update Md
0x85: 2, // Association
0x8E: 3, // Multi Channel Association
0x86: 1 // Version (2)
def parse(description) {
def result = null
if (description != "updated") {
def cmd = zwave.parse(description, commandClassVersions)
if (cmd) {
result = zwaveEvent(cmd)
else {
logDebug("Couldn't zwave.parse '$description'")
sendLastCheckInEvent()
return result
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCmd = cmd.encapsulatedCommand(commandClassVersions)
def result = []
if (encapsulatedCmd) {
result += zwaveEvent(encapsulatedCmd)
else {
log.warn "Unable to extract encapsulated cmd from $cmd"
return result
def zwaveEvent(hubitat.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x31: 3])
if (encapsulatedCommand) {
return zwaveEvent(encapsulatedCommand, cmd.sourceEndPoint)
else {
logDebug "Unable to get encapsulated command: $cmd"
return []
def zwaveEvent(hubitat.zwave.commands.versionv1.VersionReport cmd) {
logTrace "VersionReport: $cmd"
// Using this event for health monitoring to update lastCheckin
return []
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd, endPoint=null) {
logTrace "BasicReport: $cmd"
def switchVal = cmd.value ? "on" : "off"
if (device.currentValue("switch") != switchVal) {
sendEvent(name: "switch", value: switchVal)
if (endPoint == sirenEP) {
def alarmVal = cmd.value ? "both" : "off"
if (device.currentValue("alarm") != alarmVal) {
sendEvent(name: "alarm", value: alarmVal)
if (cmd.value && endPoint == beepEP) {
sendResponse(["delay 1000", basicGetCmd(beepEP)])
return []
private sendResponse(cmds) {
def actions = []
cmds?.each { cmd ->
actions << new hubitat.device.HubAction(cmd)
sendHubCommand(actions)
return []
def zwaveEvent(hubitat.zwave.Command cmd) {
logTrace "unhandled: $cmd"
return []
private getEndPoints() { [sirenEP, beepEP, continuousToneEP, repeatingBeepEP] }
private getSirenEP() { return 1 }
private getBeepEP() { return 2 }
private getContinuousToneEP() { return 3 }
private getRepeatingBeepEP() { return 4 }
private sendLastCheckInEvent() {
state.lastCheckInTime = new Date().time
logDebug "Device Checked In"
sendEvent(name: "lastCheckIn", value: convertToLocalTimeString(new Date()), displayed: false)
private convertToLocalTimeString(dt) {
def timeZoneId = location?.timeZone?.ID
if (timeZoneId) {
return dt.format("MM/dd/yyyy hh:mm:ss a", TimeZone.getTimeZone(timeZoneId))
else {
return "$dt"
private isDuplicateCommand(lastExecuted, allowedMil) {
!lastExecuted ? false : (lastExecuted + allowedMil > new Date().time)
private logDebug(msg) {
if (settings?.debugOutput != false) {
log.debug "$msg"
private logTrace(msg) {
// log.trace "$msg"
I made the changes you recommended and it didn't work. This loads the same driver configuration as the newer Aeon Sirens.
I second this. What is wrong with the built-in driver?
