ControlByWeb Thermocouple to 1-Wire Adapter
I think I'm going to give this a whirl.
Hook it up to a Fibaro Smart Implant.
Comments?
edit: Well, I ordered the stuff. Yeah, it's a gamble, but intriguing. I ordered a 16' thermocouple that could reach to the basement and then connect to an existing Fibaro Smart Implant. If all goes well, lol.
https://www.controlbyweb.com/accessories/thermocouple-one-wire-adapter.html
https://www.controlbyweb.com/accessories/x-tc1w-k-users-manual.pdf
what are you trying to measure? the direct DS18B20 temp sensor is crazy-cheap for -55 ℃ ~ +125 ℃ . Many sources of diff cables on Amazon and elsewhere.
I can see thermocouple being useful for grill-smoker control, but running a grill over zwave seems like a recipe for disaster. Likewise doesn't belong in life-safety. I have found it useful to just monitor if the hot water pipe is warm or not, to just strap a zigbee contact+temp sensor to the pipe. Furnace/AC is even easier to drop a sensor into a duct end.
That is an interesting adapter for potentially wide temp range. I will save this text for reference= " Thermocouple to 1-Wire Adapter
Thermocouple to 1-Wire Adapter compatible with select ControlByWeb devices (see below).
Overview
The X-TC1W-K is a thermocouple to 1-Wire signal adapter for use in a broad range of industrial applications. It works directly with X-400 Series, X-600M, and WebRelay Wireless modules with a 1-Wire Bus (X-410, X-420, etc.),"
It's for my information, not control, although it could prod me into doing something, like adjusting the air for better combustion, or whatnot. So, I guess that's kind of control. :slight_smile:
I'd like to know what the temperature of the top of my wood stove insert is. I already have a thermo controller with a thermocouple that turns on the fan at a certain temperature, and then goes to high speed at another higher temperature.
I like to keep the stove top at 700F or less, but it's gotten higher, lol
[quote="ero4444, post:2, topic:117919"]
That is an interesting adapter[/quote]
I couldn't find a thermocouple that would interface with Hubitat, except something by WirelessTag, and that required their cloud. This would be all local. The Fibaro SI I installed reports three temps on a tank, and is working great. If I could add what it thinks is just another 1-wire sensor, and it works, I think it'd be great.
I've used a lot of CbyW stuff - the devices have proven reliable and the support has been first rate.
I have not tried to use any of it with Hubitat.
Frederick
I'm hoping it will merely convert the output of the thermocouple into a DS18B20 signal that the Fibaro Smart Implant can read. I hope not to get further involved with CbyW than that. I hope.
I just installed the 'Konnected Pro' to connect with my old alarm system hard wired sensors. An added benefit that I didn't realize was that you can connect multiple DS18B20's to it. I have (2) sensors on one zone currently and it works like a charm.
I will say that I found the Konnected to be very easy to interface with my C8 (other than downloading apps and drivers). They have excellent step by step directions.
I believe you can also use the DS18B20's with the less expensive Konnected products.
Didn't work. Oh well.
