yep that's it. If you want to get the most out of the pre-release be sure to install the smartly JSinjector via HPM. But that is mostly for drag n drop. Caution if using stacked tiles you cannot use drag n drop (it will mess them all up)
On a side note, as a heavy Sonos users, I ended up adding a Raspberry PI to my setup and installed the Sonos HTTP framework and hooked up a Momentary Switch so I could do some more advanced voice controls like "Alexa, play music outside" which will join my outside amp to the corresponding speaker (upstairs) I know will be playing. Likewise I say "Alexa, stop music outside" and it splits the outside speaker from the group playing music". So much better than manually pulling out my phone to join/unjoin speakers.
Sonos HTTP allows a whole bunch of advanced Sonos control you can easily trigger with rest calls via RM or the Momentary switches I'm using for Alexa/Homekit easy support.
Once you add a RPI (or any really always on device), you might also end up exploring other awesomeness like Homebridge (this has made my life and WAF so much better for specific scenarios) if your' using apple devices, or Node-Red (I've installed it but haven't done anything with node red yet) is another awesome advanced tool many here are using to complement HE.
I have a raspberry pi coming alive in the next week or two. I have a pool with pentair automation and I'm getting a pi with the pool controller node.js packages that integrates with hubitat.
I had a Google nest wifi system with 6 nest wifi routers using hardwired backhaul but my internet was unstable. While I debugged that I didn't want to add more network devices. I just did a factory reset and replaced the main router as it was overheating and since then my network seems more stable. So I think I'm ready to add the pi and I can easily add more things that this pi can run.
tile 17 is the top tile. Tile 64/65 are the bottom two. Note if using smartly/drag and drop once you add stacked tiles you can no longer use that feature (it will break the stacks)
Hello all, apologies for jumping in on this thread with another question, but it does relate to Sonos.
I do see many people using Dashboard and Alexa to control their speakers. In our home, we've actually gone another way and are using the Lutron Pico integration. This isn't going through HE, even though both the Picos and Sonos speakers are paired top HE.
So, long story short, we aren't crazy about how the integration between Lutron and Sonos is working. Our main gripe is how the middle button operates. Instead of cycling through favourites and replacing the Queue as it goes, our playlists end up getting stacked together in a mish mash of everything. Not ideal. I've spoken to techs at Sonos and they told me that I had to speak with Lutron (a wild goose chase if you ask me).
Any advice on how I can create this functionality within HE? When I look at the device page, I don't see anything similar to what I am looking for,
I'm looking for a way to cycle through favourites on my Sonos Speakers from Pico (but could be any remote), abnd replace the queue as I go.
From there, I can get into some more advanced functionality, but I'd liek to tackle this one first.
@TechMedX, CSS code works brilliantly thank you. I had to tweek some of the vertical positioning, which I assume was due to the fact I'm not using Smartly. I've copied the changed code below for anyone who follows that's interested. I'm working on a 3-speaker and 4-speaker combo, as well. If anyone wants that, just ping me and I'll post that too.
I am having one problem with the Virtual Music Player app from @Cobra. When I change the volume of the parent virtual player, all the children change volume too as expected, but only for a minute or so, then they revert to their previous settings. My guess is that this has something to do with the fact that I'm not using Sonos groups. Even though the VMP docs on Cobra's website suggests this works for any speaker device, not only Sonos. I could use RM4 to could everything in sync, but I'd really rather use VMP if feasible.
In my setup, I'm using one Sonos as a source and a bunch of dumb speakers. In between, I've got a smart matrix amp that does the source and speaker selection. Any ideas?
There's literally nothing else attached to the speaker devices. confused. Could it be because I'm not using Sonos speakers? Will check out SVC, thanks Andy.
Edit: I wonder if I've messed up the config of Virtual Music Player app. Since I have a bunch of non-Sonos speaker devices and just one Sonos that I use as a source, I created a virtual device and then just picked one of the speakers to use as the master in. your app. Wonder if I should be configuring the app differently?
Hosting Sonos HTTP on an RPI (where I also - unrelated- have Homebridge installed which has been great)
I use the HTTP Momentary switches to trigger Sonos HTTP commands like grouping/ungrouping as you see in the screenshot.
And I use the native Sonos integration to do things in apps like RM to play a specific song file if motion is detected while in away more, or to use Sonos as speach to text speakers for things like HSM.
Yes that helps very much. I just need to really wrap my head around this node.js stuff I guess and learn. I feel like I've jumped off the high dive without swimming lessons.
I'm hopeful that I can get those installed on my NAS under docker as that's where I have almost all my home stuff so far. I do have a pi but it's just one more thing to ssh into and manage so I've been trying to dockerize everything under one NAS point.
I will spend some time trying to understand the tools you have pointed out, what you're doing is exactly what I'm trying to do so it's very appreciated!
Cool cool.
Yeah, I took a fast route by installing the RPI image here from community member @csteele which already has NodeJS, Node-Red (I don't use this yet) and HomeBridge on it.
Then installed HTTP Sonos using their instructions.
Awesome -- I hope it works for you. It's also listed on HPM if you prefer to install from there. But check the readme on GitHub for installation and usage instructions, particularly the webhook part if you want to avoid polling for updates.
Cool thanks. One question I have is... have you exposed these button virtual devices to Alexa?
Curious if I could tell Alexa "Join outdoor speakers" and get her to "click" the right button here.
No, I only use them as part of other automations (for example, push a certain button when a scene switch is activated). I don't think Alexa can support buttons directly, but you could still use a virtual switch to push this button in a Rule Machine rule.
