Control appearance of dashboard tile connected to a virtual switch
Perhaps I've not used the right keywords and tricky phrases but I've not found a discussion of what I'm trying to do. Maybe I'm going about it wrong?
I have a virtual switch and a tile for it on a dashboard. I'm using @kevin's MQTT app (in beta) which sends out the state change of the virtual switch when I click on the tile. I read that MQTT topic on a server and use it to start/stop a process there. So far, so good. The piece I'm missing is that I want the tile to remain in the "hourglass" appearance until HE gets a MQTT message back saying that the process was started/stopped. Can this be done?
Put another way, how does one control a tile's dynamic appearance? Bonus points for doing so externally.
@neonturbo suggested in another topic that I tag some folks here for a better shot at a solution. So, @aaiyar since you are the walking encyclopedia on this forum got any tips?
I would tag @kevin. I don't use the MQTT app. However, is the retain flag true or false on the messages being sent? If the flag is true, the last state will be sent upon a re-connect, meaning you'll always see either on or off.
My bad, it's not an MQTT question, it's how do I control the tile appearance question.
Aha. I don't use the Dashboard ...... so I'm useless over here!
Not THAT'S a first! JK
Know who to tap? Obviously my original post didn't get a response.
HE staff ..... or someone who knows a ton about Dashboard like @TechMedX
thanks @aaiyar for the tag
I must start by saying I know nothing of MQTT - not what it does or even what it stands for (not taking the time to google it today, and learn either :slight_smile: )
If you are using smartly for your dashboards it may be possible to adjust the icon depending on what HE's state shows. Dashboard icons are set by the state and cannot to be told to "wait" to my knowledge.
Shades for example have closed, opening, partially open, open, closing, partial closed, closed (unknown). Therefore we can create an icon based on each state.
If you can configure the MQTT device as a virtual shade, or other VD has has a state structure like that then yes we can easily create what ever icons you want for each state. If you are working with just on/off switch states, no, not to my knowledge
Yeah, sorry, mentioning MQTT was a bad idea and not relevant to tile appearance.
I'll checkout smartly, thanks!
If you need icons post request here (sooner the better my covid time is drying up) :wink:
https://community.hubitat.com/t/smartly-custom-icon-requests/39540
Thank you
The retain flag on a 'command' .../set to a device will not be retained but the states that a device reports are sent retained.
I think you're approaching this wrong.. the device should not be an internal HE device but an external MQTT device that you are asking to do something (command) and it then reports back when it has completed that task via it's status payload on MQTT which then gets displayed in HE Dashboard.
The dashboard will always show the internal state of a device as HE sees it. If this is a virual device i.e. one originated and maintained by MQTT and imported to MQTT (HE) then when clicked the tile sends a command to MQTT - you start/stop your process and should report that completion back in the devices status on MQTT which will update the status in HE Dashboard. It won't show an hourglass inbetween but it won't show an update either. Once the process completes it will then show this on the dashboard. Consider your process as a remote network device.
If you are wanting the solution you outline then you need a driver that shows three states for a device 'off' 'working' and 'on' I guess. But you definitely need your process status to feedback via MQTT to update the dashboard.
Perhaps if I explained it differently. If you use an internal HE device for this it just turns on and off and so the device updates immediately in dashboard , as you're seeing. HE has no knowledge that you are triggering an external device (process) from this so has no ability to know if that happened or when has completed.
(so intercept the ...onoff/set command in NodeRED or whatever - trigger your process and then update the .../onoff status with the result and HE will then display that on the dashboard)
Would it be possible to tie those actions to the state mentioned above. So trigger a "opening" state on a 'send' command or something to that effect.
@TechMedX - not sure I've understood your question correctly.
What 'commands' you can send depends on the device driver - a switch for example only supports on|off whereas level has 0-100 values. There are devices that could have high,medium,low as settings for example a fan speed. Likewise devices can have just a couple of commands but several states like opening, closing, closed, open. Covers / garage doors are similar to this they have an intermediary 'working on it' state. Choosing an appropriate device driver for this will allow these states to be displayed on the dashboard as either icons or attribute values.
I am not sure in Steven's case if the 'process' has several states, 'triggered' 'running' 'completed' 'failed' or not and if it takes some time to run.
The MQTT app can map expected attribute values like 'active' 'inactive' to 'running' 'completed' or whatever for both status and commands
The "device" on the other end is a shell script that uses systemctl to control my video motion system process. If not a virtual switch on a dashboard tile then what do I use in Hubitat to initiate the MQTT comands?
You are at the moment I guess creating a virtual device within HE and publishing the status of that device to MQTT and using that status to trigger your script (??) Instead you should create a virtual device within my app that is updated from an existing MQTT device (your process).
That device in HE then reflects the reported status on MQTT.
Then from a button on the dashboard for that device send a command ( .../set) to that device which triggers your 'process' launch. When that has been received you publish a status update back onto MQTT and that will be immediately reflected in the dashboard tile state.
Got it. Thanks :+1: :+1:
