always hit the config button after changing drivers
as Mike Maxwell has reported: just because you tell a device to report at a certain frequency, doesn't mean that the device "listens". Some do, and some do not.
Well, it looks like you did everything correctly.
As stated, it could very well be a sensor that just doesn't listen to the reporting configuration that it has been sent.
I donāt see temperature reporting configurations for this device in ZHA/Z2M code, so probably configuring is not supported. The device may respond with success code to the configuration command, but actually do nothing.
