I have a bunch of the window/door sensors in the house, appear to be linked wirelessly to a brinks controller. Can I repurpose these or are they proprietary to the security system?
According to their FAQ, the sensors use a "proprietary signal" that goes undefined, but definitely not z-wave or zigbee since they make performance comparisons to those.
Your Constellation Connect Hub is compatible with Z-Wave, Zigbee, Wi-Fi and 345 MHz.
But like @hydro311 said it doesn't say exactly which are which. Some of those devices look like Zigbee and Z-wave off the shelf items.
That siren appears to be Linear or Go Control ( LINWA105DBZ1), the glass break a model ITIGLB01 Linear, and the bulb is clearly labeled Go Control if you squint at the picture. If so, these may (and I emphasize the may) be Z-wave.
The keypad appears to be Centralite, possibly an older Zigbee model. Maybe the 3400? The power plug looks very Centralite-ish to me as well.
The window and door sensors I don't recognize, they might be a 2GIG-DW10E judging by the shape, and the 345Mhz spec on both. If they are 345Mhz, they aren't compatible with Hubitat. At least not that I am aware of.
And I'm an idiot -- I misread this entry in the FAQ as saying they use a proprietary protocol for everything (and were just comparing to ZB / ZW), but now I see what it's actually saying is that they use proprietary for something, but also use ZB /ZW.
