Connectivity failure after upgrade to version 2.5.3.123
After upgrading my C8 Pro to platform version 2.5.3.123, the C8 lost connectivity to The Home Remote(THR) and Multi System Reactor (MSR). (Given the apparent size and content of .123 I will not surprised if it contains some defects.) MSR uses "Maker API for Reactor" to connect to Hubitat. It lost all connectivity. THR apparently also uses Maker, but it is unclear to me whether it uses the generic built-in Maker. THR failed a bit differently. It experienced rapidly rolling connects/disconnects. I tried both a reboot and a database restoration, neither of these restored the inter-system connectivity. Restoration of service was only accomplished by restoring the previous platform version - 2.5.2.134. I recommend that anyone using Reactor or THR be prepared to go back to their previous platform version (this is different from a database upgrade) or avoid upgrading to 2.5.3.123, and instead wait until Hubitat isolates and corrects this problem in a future release.
I use several connections to external systems, including node-red, homebridge, and Alexa, with no issues. So the issues you’ve encountered do not extend generically to all external systems.
You may wish to tag other users of MSR to learn if their experience with 2.5.3.x matches yours.
Same here, no issues with several external integrations running on my hub.
I’m sure it’s possible that something in platform version 2.5.3 is affecting the specific integrations OP is using, particularly if reverting to a previous version of the platform resolved the issue.
But there’s no way to know that without more information.
Rather than waiting for HE staff to identify a possible bug that might be affecting an unclear number of users, have you done any simple troubleshooting like checking for errors or warnings in your hub logs?
Or even rebooting the hub one more time.
