@chad.andrews How long was the wire you used for the antenna?
Just keep in mind that length is probably optimized for US z-wave (908.42 MHz). Is that correct @chad.andrews?
I thought he was referring to a zigbee switch. I know there would be a different length for different frequencies.
I have some sonoff ZBminis mounted in metal weatherproof boxes and the LQIs are dismal.
I think that switch is an EVALOGIK z-wave toggle switch. I think @chad.andrews was demonstrating that as an example of adding an external antenna to an existing device to improve its function at a distance.
Edit:
I think a simple dipole zigbee 1/2 wave antenna would be 2.4 - 2.5 inches
TP-Link wi fi devices might work for you, via the TP-Link integration app.
Mike M
@kuzenkohome @aaiyar yep, that's a Zwave switch, 12 3/8 inches long. Just an example to follow, Zigbee would be a different length, you would need to optimize for 2.4 GHz.
I just ordered one of these for $16.61 CDN shipped:
Not that I need one.
But there's been mention of them on the forum for awhile now.
And they're in stock at this store that I've ordered from before, so, wth.
Is that a repeater, or a full-on Zigbee controller?
Either or, but not both, unless you have more than one.
Tradfri repeater has arrived and has been installed. Now have Zigbee devices running in the shed!
Thanks everyone.
