Connecting Honeywell Lyric to Hubitat via a relay
HI everyone. I’d like to integrate my Honey Alarm panel so that, for example, when a door opens, it trips a relay on my hubitat, so that I can make additional things happen, like the AC turn on.
Do you have any suggestions on how best to make this happen
The question is what you have from the Honey Alarm panel to trip something. Does it have a relay that it trips when the door opens? Does it have some kind of an alert system? Can it make a web request when something happens?
The Honeywell has its own, mediocre z-wave system, but it’s a walled garden and can’t connect to the Internet. I’m thinking primarily about the fact it can turn on all the z-wave-controlled lights, for instance, if it goes off. But I don’t want to set up separate z-wave lights, etc., just for that purpose.
Thanks for your help!!!
do you need the current system to keep working.. if not look at konnected to hook it up to hubitat
That may be the way to go. I actually got started with z-wave when I began to tinker with the Honeywell system, only to discover it’s like buying a car with no steering wheel.
