Connecting Aqara sensors to XBee Coordinator
I have set-up an XBee S2C module as a coordinator and set the parameters to connect to Home Automation end-units. When using the Scan option of the XCTU, my Aqara sensors appear OK in the connected devices. But I am not able to receive any Event from the sensors (e.g. closing and opening a Aqara magnetic switch). I am using the XCTU Consoles Working Mode to check for any Explicit Rx Indicator - but nothing is received.
Are there some other settings I should do?
Hi @israelf
I think you're in the wrong community; this community is centered around using the Hubitat Elevation hub as a zigbee coordinator and automation hub.
