Conditions not obeyed
Still a noob. I have a set of conditions on some actions, yet the actions are happening in spite of the conditions not being true. I am sure I am missing something basic here
Would be better if you showed the complete rule, from the opening page.
Like this:
mine doesn't look like that at all. How do i get to that code?
Conditions are just a bank of things that can be used within a rule, they themselves don't actually modify or limit a rule.
You need to apply those conditions to your actions.
ok thanks
That first video should start you out, but this is the more advanced settings.
If you are still stuck after watching those, come back and we can walk through it.
I think this will work. Many thanks!
Yep, that should work. :+1:
You could add your phone notification if you still want that. You wanted that notification if the outlet was on, or were you just testing things?
Also, it is good practice to end these with an END IF. It probably won't make a difference here, but a good habit to start doing.
you dont need the temp check in the if as it is already in the trigger.. you would need that if you check changed but not for your specific case..
you also need and end-if at the end of the rule
i added the phone notification
i guess i need to go further in the video to find how to add the endif
is it ok that the plug status says true and false here?
you add end-if in the same block as a condition. it is one of the condition sub-menus.
the true false is fine, ,that is the current rule truth value
got it!
and killed the temp condition
