Hi,
I am editing a more extensive rule and added an IF statement before some code since I wanted to validate a condition before executing a bit of the code. I then inserted an ELSE statement and finally and EN-IF statement. When I entered the END-IF statement, the contion in the IF statement disappeared (Please see picture below).
I think it is still there, so to speak, as I was able to press DONE and didn't get any complaints.
If I go in and edit this line it looks like this:
If I select edit it looks like the editor views the line as missing and gives an parenthesis error. But I can see the line that is missing as an existing option to add.
If I then add a parenthesis RM accepts the statement but does now give double statement error. Note that both lines are still missing (Se picture below)
I added the line again and removed the broken condition line and RM accepts this, but the statement is still missing, and a pair of parenthesis appears to have been added.
I got the same error at another location in the same rule earlier but that time, I could ad the same statement again from the list of statements, as I tried to do in the example above, and the statement appeared and all was well. The only difference to the first time the bug occured was that I didn't get the '**Broken condition **' error (Se picture below)
Pleases advice
EDIT: I updated tot eh latest update, 2.3.5.140, but this unfortunately did not solve the issue.
