I would like to create a rule with a trigger where an action would be executed only if the same action was not executed in last 60 minutes.
For example: pH sensor gets data above threshold value and triggers an action to dose pH- liquid, but only if dosing was not already performed within last 60 mins. pH correction results are detected very slowly and I want to mute any pH- dosing actions until I'm certain that enough time passed.
Any suggestions how to set such condition on timing of past action?
just to be clear (I am still a noob with Rule Machine): private bool should be within my rule for pH (that has its own sensor trigger)? I wonder how can I add the timer trigger on top of existing sensor trigger...
Thanks, your idea let me dig and explore deeper, here is how I solved it:
(no required expression)
Trigger:
if AvgpH > 6.0
Actions:
If (Variable Busy = false): dose 10ml pH-
Set Variable Busy to true
Delay 1:00:00
Set Variable Busy to false
I don't know if the Delay is holding back (pausing) the whole rule for an hour - I'd prefer that the rule finishes without delay each time it is triggered.
