Hope this is an appropriate category. I think this may be a Lock Manager topic.
C-8 Pro
2.3.9.136
I am beyond frustrated. The HE worked well some months ago. Things started getting inconsistent. My debugging over the months has me running in circles. The list of things that do not work is a lot longer than the list of what does work. Won't list all the things I've tried. Voluminous.
I started the journey about 7 years ago. Now have a collection of around 58 devices; Zwave, Zigbee, wifi. Primarily Shelly switches, Sonoff & Aqara motion, 2 Yale locks, a couple different brands of dimmers, a few 110 wall plugsb. Things began getting less and less reliable. Just today migrated from a C-8 to a C-8 Pro hoping I simply had a hardware failure. No such luck.
I would love to go back to zero and start over but the thought of unpairing and repairing Zwave devices is overwhelming. I suppose the same would be true for Zigbee devices.
As an example let's talk about the locks. 2 @ YRD256
- They worked initially. Added users and codes.
- Later I couldn't add codes for users.
- Now can't create users and can't add codes to the existing
- Activity on one lock shows up in the logs but lock #2 does not.
- I see the lock manager (I think) going through a retry loop in the logs. Will include a little of that.
- Tried to delete the Lock Manager and re-install. The config data seems pervasive. After the reinstall the same users and codes were there.
- Both locks are about 20' from the hub
- Have them set for verbose logging
app:8202024-05-25 04:17:51.472 PMtracegetLockCodesFromDevices- device:Lock :: Front Door
app:8202024-05-25 04:17:51.467 PMinfogetLockCodesFromDevices- devices:[Lock :: Front Door, Lock :: Apartment]
dev:5642024-05-25 04:01:40.029 PMwarnNo event seen from the device for over 3 hours! Something is not right... (consecutive events: 499)
dev:5632024-05-25 03:56:10.025 PMinfoNo VALID lastCheckin event available! This should be resolved by itself within 1 or 2 hours and is perfectly NORMAL as long as the same device don't get this multiple times per day...
dev:3292024-05-25 03:32:59.218 PMinfoLights :: Apt Door Exterior button null was pushed
dev:5642024-05-25 03:28:57.033 PMwarnEvent interval INCORRECT, recovery mode (Normal) ACTIVE! If this is shown every hour for the same device and doesn't go away after three times, the device has probably fallen off and require a quick press of the reset button or possibly even re-pairing. It MAY also return within 24 hours, so patience MIGHT pay off.
dev:5642024-05-25 03:28:57.028 PMwarnOne or several EXPECTED checkin events have been missed! Something MIGHT be wrong with the mesh for this device. Minutes since last checkin: 90662 (maximum expected 90)
app:8202024-05-25 03:28:54.613 PMinfogetLockCodesFromDevices- complete
app:8202024-05-25 03:28:54.610 PMdebuggetLockCodesFromDevices- lockCode:2={code=1963, name=Simona}
app:8202024-05-25 03:28:54.607 PMdebuggetLockCodesFromDevices- lockCode:1={code=5862, name=Elisa}
app:8202024-05-25 03:28:54.603 PMtracegetLockCodesFromDevices- device:Lock :: Apartment
app:8202024-05-25 03:28:54.600 PMdebuggetLockCodesFromDevices- lockCode:3={code=7775, name=David}
app:8202024-05-25 03:28:54.597 PMdebuggetLockCodesFromDevices- lockCode:2={code=5862, name=Elisa}
app:8202024-05-25 03:28:54.594 PMdebuggetLockCodesFromDevices- lockCode:1={code=1963, name=Simona}
app:8202024-05-25 03:28:54.591 PMtracegetLockCodesFromDevices- device:Lock :: Front Door
app:8202024-05-25 03:28:54.588 PMinfogetLockCodesFromDevices- devices:[Lock :: Front Door, Lock :: Apartment]
app:8202024-05-25 03:24:36.249 PMinfogetLockCodesFromDevices- complete
app:8202024-05-25 03:24:36.247 PMdebuggetLockCodesFromDevices- lockCode:2={code=1963, name=Simona}
app:8202024-05-25 03:24:36.244 PMdebuggetLockCodesFromDevices- lockCode:1={code=5862, name=Elisa}
app:8202024-05-25 03:24:36.240 PMtracegetLockCodesFromDevices- device:Lock :: Apartment
app:8202024-05-25 03:24:36.238 PMdebuggetLockCodesFromDevices- lockCode:3={code=7775, name=David}
app:8202024-05-25 03:24:36.235 PMdebuggetLockCodesFromDevices- lockCode:2={code=5862, name=Elisa}
app:8202024-05-25 03:24:36.232 PMdebuggetLockCodesFromDevices- lockCode:1={code=1963, name=Simona}
app:8202024-05-25 03:24:36.228 PMtracegetLockCodesFromDevices- device:Lock :: Front Door
app:8202024-05-25 03:24:36.226 PMinfogetLockCodesFromDevices- devices:[Lock :: Front Door, Lock :: Apartment]
app:8202024-05-25 03:24:19.716 PMwarnactions: User junkuser, code 5555 --will be added to [Lock :: Front Door]
app:8202024-05-25 03:24:19.713 PMinfogetCodeUsage- result:[]
app:8202024-05-25 03:24:19.709 PMdebuggetCodeUsage- lockCodes:[[did:257, code:1963, name:Simona, codeNumber:1, codeState:e, codeOption:e], [did:257, code:5862, name:Elisa, codeNumber:2, codeState:e, codeOption:e], [did:257, code:7775, name:David, codeNumber:3, codeState:e, codeOption:e], [did:416, code:5862, name:Elisa, codeNumber:1, codeState:e, codeOption:e], [did:416, code:1963, name:Simona, codeNumber:2, codeState:e, codeOption:e]], code:5555
app:8202024-05-25 03:24:19.705 PMinfogetNameUsage- result:[]
app:8202024-05-25 03:24:19.701 PMdebuggetNameUsage- lockCodes:[[did:257, code:1963, name:Simona, codeNumber:1, codeState:e, codeOption:e], [did:257, code:5862, name:Elisa, codeNumber:2, codeState:e, codeOption:e], [did:257, code:7775, name:David, codeNumber:3, codeState:e, codeOption:e], [did:416, code:5862, name:Elisa, codeNumber:1, codeState:e, codeOption:e], [did:416, code:1963, name:Simona, codeNumber:2, codeState:e, codeOption:e]], name:junkuser
What next? Any ideas? I'm lost.
A simple question .... how can the "app:nnn" or "dev:nnn" value be correlated back to the Application or Device? Thank you
Thanks much for any help
David
