Hello,
I have one of the older Greenwave Reality (TCP Connected) gateway hubs and bulbs. As it is known, the company behind the shutdown their servers and now the bulbs only work locally via the smart phone app.
This has worked well for me for years but now I want to improve this system, so I have ended up here.
My question, is Hubitat compatible with Greenwave Reality (TCP Connected) gateway hub and bulbs?
That being said, if there is a published API to access the gateway, it may well be possible to write a LAN integration for it. So, is there a documented API?
...if there is a published API to access the gateway
A while ago someone reverse-engineered the command protocol via Wireshark so a web interface does exists using this information.
See here: https://github.com/bren1818/TCPLightingWebInterface/blob/master/api.php
Also, Smart Things does claim compatibility. See here: https://github.com/home-assistant/core/tree/dev/homeassistant/components/greenwave
