Compatibility advice for TechniSat and EcoDim
Hello everyone,
The devices listed below are not listes as compatible devices. Do you have advice for
TechniSat:
EcoDim:
devices?
TechniSat is mentioned here: Best reliable zwave switch? - #2 by mlatz , but I could not find more information on how they work with my Hubitat C-8 Pro.
I tried to add the TechniSat switches as generic switches (all types, one after another), but without success.
I guess if the manufacturers do not provide information, the use of these devices is probably not possible with Hubitat?
Hallo, yes I talked about Technisat, but with the GIRA series I have no experience.
I guess the TechniSat switches are all the same electrically. Probably only the mechanical components differ from each other.
Did you use TechniSat switches with the Hubitat?
I habe returned the Technisat switches and I am using Shellys instead
For Eco.Dim, I unfortunately could not find out more about compatibility with hubitat
