Common Methods error?
I'm using some of the methods in Common Methods | Hubitat Documentation
Most appear to work fine, for example, getSunriseAndSunset returns:
{"sunrise":"2024-05-30T12:24:00+0000","sunset":"2024-05-31T03:51:00+0000"}
as expected.
But one: timeToday
is causing an error:
{"error":true,"type":"java.lang.Exception","message":"An unexpected error occurred."}
and two:
getTomorrowsSunrise
getTodaysSunset
Don't return any information at all.
Are they implemented?
Thanks.
Works for me. Perhaps not well documented.
        case "sunrise":
            String sunrise = outputFormat.format(getTodaysSunrise())
            return [value: sunrise, dataType: "Date"]
            break
        case "sunset":
            String sunset = outputFormat.format(getTodaysSunset())
            return [value: sunset, dataType: "Date"]
            break
        case "sunriseTomorrow":
            String sunriseTomorrow = outputFormat.format(getTomorrowsSunrise())
            return [value: sunriseTomorrow, dataType: "Date"]
            break
        case "sunsetTomorrow":
            String sunsetTomorrow = outputFormat.format(getTomorrowsSunset())
            return [value: sunsetTomorrow, dataType: "Date"]
            break
I think this is the required import:
import java.text.SimpleDateFormat
Thanks. I added that import. Unfortunately, same issues.
These are all the imports defined in my app.
import groovy.transform.Field
import java.util.Date
import java.time.LocalDate
import java.time.LocalDateTime
import java.text.ParseException
import java.util.regex.Pattern
I'm on a very recent version: 2.3.9.136
My code accessing those two.
What are you expecting timeToday to return? Sounds a bit like now().
Thanks. Tried those too. I just get a blank response.
Oddly getSunriseAndSunset works perfectly.
I just updated my prior response.
"What are you expecting timeToday to return? Sounds a bit like now()."
I'm hoping it gives me the local time on the hub. I'm writing a custom (off hub) app, and I need to make sure the app's time is the same as the hub's time.
I do remember having an issue with one of the calls but I didn't really need it. I think this one was probably it. But the other two work for me:
getTomorrowsSunrise
getTodaysSunset
Thank you. I think I figured it out. I think the property I was using was incorrect. I'll play with it some more. Much appreciated.
