I am building a driver for a thermostat that support the class Schedule (0x53) v1, but it looks like HE does not support this CC or I doing something wrong when paring the msg:
@mike.maxwell would probably be the one to ask/knows for sure.
I don't see a corresponding capability in the capability list (unless it is buried in the ThermostatSchedule capability - no idea what that does as I can't find a corresponding ST or other capability named this), so I would guess not? But could be wrong... https://docs.hubitat.com/index.php?title=Driver_Capability_List
You can still work with the class, even though we don't have it implemented...
.format() returns a given zwave command as a string of hex bytes which are then sent to the device.
If you know the class, command and how to format the payload you can just return the string directly...
Ie basicSet(value:0) would be: return "200100"
Description text would need to be parsed within the driver as well.
